System Administration Guide: Devices and File Systems
RCM Script Tasks
The following sections describe the RCM script tasks for application developers and system administrators.
Application Developer RCM Script (Task Map)
The following task map describes the tasks for an application developer who is creating an RCM script.
Task
Description
For Instructions
1. Identify the resources your application uses.
Identify the resources (device names) your application uses that you could potentially dynamically remove.
cfgadm(1M)
2. Identify the commands to release the resource.
Identify the commands for notifying the application to cleanly release the resource from the application.
Application documentation
3. Identify the commands for post-removal of the resource.
Include the commands for notifying the application of the resource removal.
rcmscript(4)
4. Identify the commands if the resource removal fails.
Include the commands for notifying the application of the available resource.
rcmscript(4)
5. Write the RCM script.
Write the RCM script based on the information identified in tasks 1-4.
Tape Backup RCM Script Example
6. Install the RCM script.
Add the script to the appropriate script directory.
How to Install an RCM Script
7. Test the RCM script
Test the script by running the script commands manually and by initiating a dynamic reconfiguration operation.
How to Test an RCM Script
System Administrator RCM Script (Task Map)
The following task map describes the tasks for a system administrator who is creating an RCM script to do site customization.
Task
Description
For Instructions
1. Identify the resources to be dynamically removed.
Identify the resources (device names) to be potentially removed by using the cfgadm -l command.
cfgadm(1M)
2. Identify the applications to be stopped.
Identify the commands for stopping the applications cleanly.
3. Identify the commands for pre-removal and post-removal of the resource.
Identify the actions to be taken before and after the resource is removed.
rcmscript(4)
4. Write the RCM script.
Write the RCM script based on the information identified in tasks 1-3.
5. Install the RCM script.
6. Test the RCM script.
Naming an RCM Script
A script must be named as vendor,service where the following applies:
vendor
Is the stock symbol of the vendor that provides the script, or any distinct name that identifies the vendor.
service
Is the name of the service that the script represents.
Installing or Removing an RCM Script
You must be superuser (root) to install or remove an RCM script. Use this table to determine where you should install your RCM script.
Table 6–1 RCM Script Directories
Directory Location
Script Type
/etc/rcm/scripts
Scripts for specific systems
/usr/platform/`uname -i`/lib/rcm/scripts
Scripts for a specific hardware implementation
/usr/platform/`uname -m`/lib/rcm/scripts
Scripts for a specific hardware class
/usr/lib/rcm/scripts
Scripts for any hardware
ProcedureHow to Install an RCM Script
  1. Become superuser.
  2. Copy the script to the appropriate directory.
    See Table 6–1.
    For example:
    # cp SUNW,sample.pl /usr/lib/rcm/scripts
  3. Change the user ID and the group ID of the script to the desired values.
    # chown user:group /usr/lib/rcm/scripts/SUNW,sample.pl
  4. Send SIGHUP to the RCM daemon.
    # pkill -HUP -x -u root rcm_daemon
ProcedureHow to Remove an RCM Script
  2. Remove the script from the RCM script directory.
    For example:
    # rm /usr/lib/rcm/scripts/SUNW,sample.pl
  3. Send SIGHUP to the RCM daemon.
ProcedureHow to Test an RCM Script
  1. Set environment variables, such as RCM_ENV_FORCE, in the command-line shell before running your script.
    For example, in the Korn shell, use the following:
    $ export RCM_ENV_FORCE=TRUE
  2. Test the script by running the script commands manually from the command line.
    For example:
    $ script-name scriptinfo
    $ script-name register
    $ script-name preremove resource-name
    $ script-name postremove resource-name
  3. Make sure that each RCM script command in your script prints appropriate output to stdout.
  4. Install the script in the appropriate script directory.
    For more information, see How to Install an RCM Script.
  5. Test the script by initiating a dynamic remove operation.
    For example, assume your script registers the device, /dev/dsk/c1t0d0s0. Try these commands.
    $ cfgadm -c unconfigure c1::dsk/c1t0d0
    $ cfgadm -f -c unconfigure c1::dsk/c1t0d0
    $ cfgadm -c configure c1::dsk/c1t0d0
    Caution – Caution –
    Make sure that you are familiar with these commands because they can alter the state of the system and cause system failures.
This example illustrates how to use an RCM script for tape backups.
What the Tape Backup RCM Script Does
The tape backup RCM script performs the following steps:
  1. Sets up a dispatch table of RCM commands.
  2. Calls the dispatch routine that corresponds to the specified RCM command and exits with status 2 for unimplemented RCM commands.
  3. Sets up the scriptinfo section.
    rcm_script_func_info=Tape backup appl script for DR
  4. Registers all tape drives in the system by printing all tape drive device names to stdout.
    rcm_resource_name=/dev/rmt/$f
    If an error occurs, the script prints the error information to stdout.
    rcm_failure_reason=$errmsg
  5. Sets up the resource information for the tape device.
    rcm_resource_usage_info=Backup Tape Unit Number $unit
  6. Sets up the preremove information by checking if the backup application is using the device. If the backup application is not using the device, the dynamic reconfiguration operation continues. If the backup application is using the device, the script checks RCM_ENV_FORCE. If RCM_ENV_FORCE is set to FALSE, the script denies the dynamic reconfiguration operation and prints the following message:
    rcm_failure_reason=tape backup in progress pid=...
    If RCM_ENV_FORCE is set to TRUE, the backup application is stopped, and the reconfiguration operation proceeds.
Outcomes of the Tape Backup Reconfiguration Scenarios
Here are the various outcomes if you use the cfgadm command to remove a tape device without the RCM script.
Here are the various outcomes if you use the cfgadm command to remove a tape device with the RCM script.
Example—Tape Backup RCM Script
#! /usr/bin/perl -w
   # A sample site customization RCM script.
   # When RCM_ENV_FORCE is FALSE this script indicates to RCM that it cannot
   # release the tape drive when the tape drive is being used for backup.
   # When RCM_ENV_FORCE is TRUE this script allows DR removing a tape drive
   # when the tape drive is being used for backup by killing the tape
   # backup application.
    use strict;
    my ($cmd, %dispatch);
    $cmd = shift(@ARGV);
# dispatch table for RCM commands
    %dispatch = (
            "scriptinfo"    =>      \&do_scriptinfo,
            "register"      =>      \&do_register,
            "resourceinfo"  =>      \&do_resourceinfo,
            "queryremove"   =>      \&do_preremove,
            "preremove"     =>      \&do_preremove
    if (defined($dispatch{$cmd})) {
            &{$dispatch{$cmd}};
    } else {
            exit (2);
    sub do_scriptinfo
            print "rcm_script_version=1\n";
            print "rcm_script_func_info=Tape backup appl script for DR\n";
            exit (0);
    sub do_register
            my ($dir, $f, $errmsg);
            $dir = opendir(RMT, "/dev/rmt");
            if (!$dir) {
                 $errmsg = "Unable to open /dev/rmt directory: $!";
                 print "rcm_failure_reason=$errmsg\n";
                 exit (1);
            while ($f = readdir(RMT)) {
                # ignore hidden files and multiple names for the same device
                if (($f !~ /^\./) && ($f =~ /^[0-9]+$/)) {
                        print "rcm_resource_name=/dev/rmt/$f\n";
            closedir(RMT);
            exit (0);
sub do_resourceinfo
      my ($rsrc, $unit);
      $rsrc = shift(@ARGV);
      if ($rsrc =~ /^\/dev\/rmt\/([0-9]+)$/) {
           $unit = $1;
           print "rcm_resource_usage_info=Backup Tape Unit Number $unit\n";
           exit (0);
       } else {
           print "rcm_failure_reason=Unknown tape device!\n";
            exit (1);
    sub do_preremove
            my ($rsrc);
            # check if backup application is using this resource
            #if (the backup application is not running on $rsrc) {
                    # allow the DR to continue
            #        exit (0);
            # If RCM_ENV_FORCE is FALSE deny the operation.
            # If RCM_ENV_FORCE is TRUE kill the backup application in order
            # to allow the DR operation to proceed
            if ($ENV{RCM_ENV_FORCE} eq 'TRUE') {
                 if ($cmd eq 'preremove') {
                         # kill the tape backup application
                 exit (0);
            } else {
               # indicate that the tape drive can not be released
               # since the device is being used for backup by the
               # tape backup application
               print "rcm_failure_reason=tape backup in progress pid=...\n"
               exit (3);
