System Administration Guide: Devices and File Systems
Installing or Removing an RCM Script
You must be superuser (root) to install or remove an RCM script. Use this table to determine where you should install your RCM script.
Table 6–1 RCM Script Directories
Directory Location
Script Type
Scripts for specific systems
/usr/platform/`uname -i`/lib/rcm/scripts
Scripts for a specific hardware implementation
/usr/platform/`uname -m`/lib/rcm/scripts
Scripts for a specific hardware class
Scripts for any hardware
