System Administration Guide: Devices and File Systems
ProcedureHow to Display PCI Slot Configuration Information
This procedure has been updated to include PCIe configuration information.
The cfgadm command displays the status of PCI hot-pluggable devices and slots on a system. For more information, see cfgadm(1M).
  1. Become superuser.
  2. Display PCI configuration information.
    • Display PCI slot configuration information.
      For example:
      # cfgadm
      Ap_Id                Type         Receptacle   Occupant     Condition
      pci1:hpc0_slot0      unknown      empty        unconfigured unknown
      pci1:hpc0_slot1      unknown      empty        unconfigured unknown
      pci1:hpc0_slot2      unknown      empty        unconfigured unknown
      pci1:hpc0_slot3      ethernet/hp  connected    configured   ok
      pci1:hpc0_slot4      unknown      empty        unconfigured unknown
    • Display specific PCI device information.
      For example:
      # cfgadm -s "cols=ap_id:type:info" pci
      Ap_Id                Type         Information
      pci1:hpc0_slot0      unknown      Slot 7
      pci1:hpc0_slot1      unknown      Slot 8
      pci1:hpc0_slot2      unknown      Slot 9
      pci1:hpc0_slot3      ethernet/hp  Slot 10
      pci1:hpc0_slot4      unknown      Slot 11
      The logical Ap_Id, pci1:hpc0_slot0, is the logical Ap_Id for hot-pluggable slot, Slot 7. The component hpc0 indicates the hot-pluggable adapter card for this slot, and pci1 indicates the PCI bus instance. The Type field indicates the type of PCI adapter card that is present in the slot.
    • Display PCIe slot configuration information.
      For example:
      # cfgadm pci
      pcie1                          unknown      empty        unconfigured unknown
      pcie2                          unknown      empty        unconfigured unknown
      pcie3                          unknown      empty        unconfigured unknown
      pcie4                          etherne/hp   connected    configured   ok
      pcie5                          pci-pci/hp   connected    configured   ok
      pcie6                          unknown      disconnected unconfigured unknown
    • Display specific PCIe device information.
      For example:
      # cfgadm -s "cols=ap_id:busy:o_state" pci
      Ap_Id                          Busy     Occupant
      pcie1                          n        unconfigured
      pcie2                          n        unconfigured
      pcie3                          n        unconfigured
      pcie4                          n        configured
      pcie5                          n        configured
      pcie6                          n        configured
      Note –
      The logical Ap_Id in most cases should match the slot label that is silk-screened on the system chassis. Refer to your platform guide for the cfgadm output of the hot-pluggable slots. The Busy field can be displayed to ensure that the Ap_Id is not transitioning to another state before a hot-plug operation is attempted.
