Use this road map to identify all the tasks for managing USB devices in the Oracle Solaris OS. Each task points to a series of additional tasks such as using USB devices, hot-plugging USB devices, and adding USB audio devices.
For information about using USB components in the Oracle Solaris OS, see About USB in the Oracle Solaris OS.
Task |
Description |
For Instructions |
Use USB mass storage devices. |
A USB mass storage device must contain a file system before you can add data to it. In addition, a USB diskette must be formatted before file systems can be created and mounted on them. This section also describes how to physically add or remove USB devices from your system. | |
Add USB audio devices. |
Use this task map to identify tasks associated with adding USB audio devices. | |
Add or remove USB devices to and from your system with the cfgadm command. |
You can logically add or remove USB devices to and from your system with the cfgadm command. |
