System Administration Guide: Devices and File Systems
EFI Disk Label
The EFI label provides support for physical disks and virtual disk volumes that are greater than 2 TB in size. This release also includes updated disk utilities for managing disks greater than 2 TB in size. The UFS file system is compatible with the EFI disk label, and you can create a UFS file system greater than 2 TB. For information on creating a multiterabyte UFS file system, see 64-bit: Support of Multiterabyte UFS File Systems.
The unbundled Sun QFS file system is also available if you need to create file systems greater than 1 TB. For information on the Sun QFS file system, see Sun QFS, Sun SAM-FS, and Sun SAM-QFS File System Administrator’s Guide.
The Solaris Volume Manager software can also be used to manage disks greater than 1 TB in this Solaris release. For information on using Solaris Volume Manager, see Solaris Volume Manager Administration Guide.
The VTOC label is still available for disks less than 2 terabytes in size. If you are only using disks smaller than 2 TB on your systems, managing disks will be the same as in previous Solaris releases. In addition, you can use the format-e command to label a disk 2 TB in size or less with an EFI label. For more information, see Example 11–6.
You can use the format -e command to apply an EFI label to a disk if the system is running the appropriate Solaris release. However, you should review the important information in Restrictions of the EFI Disk Label before attempting to apply an EFI label.
You can also use the format -e command to reapply a VTOC label if the EFI label is no longer needed. For example:
# format
Specify disk (enter its number): 2
selecting c0t5d0
[disk formatted]
format> label
[0] SMI Label
[1] EFI Label
Specify Label type[1]: 0
Warning: This disk has an EFI label. Changing to SMI label will erase all
current partitions.
Continue? yes
Auto configuration via format.dat[no]?
Auto configuration via generic SCSI-2[no]?
format> quit
Caution – Caution –
Keep in mind that changing disk labels will destroy any data on the disk.
Comparison of the EFI Label and the VTOC Label
The EFI disk label differs from the VTOC disk label in the following ways:
Keep the following restrictions in mind when determining whether using disks greater than 1 terabyte is appropriate for your environment:
Support for EFI-Labeled Disks on x86 Systems
Solaris support for the EFI disk label is available on x86 systems. Use the following command to add an EFI label on an x86 system:
# format -e
> [0] SMI Label
> [1] EFI Label
> Specify Label type[0]: 1
> WARNING: converting this device to EFI labels will erase all current
> fdisk partition information. Continue? yes
Previous label information is not converted to the EFI disk label.
You will have to recreate the label's partition information manually with the format command. You cannot use the fdisk command on a disk with an EFI label that is 2 terabytes in size. If the fdisk command is run on disk that is greater than 2 TB in size to create a Solaris partition, the Solaris partition is limited to 2 TB. For more information about EFI disk labels, see the preceding section.
Installing a System With an EFI-Labeled Disk
The Solaris installation utilities automatically recognize disks with EFI labels. However, you cannot use the Solaris installation program to repartition these disks. You must use the format utility to repartition an EFI-labeled disk before or after installation. The Solaris Upgrade and Live Upgrade utilities also recognize a disk with an EFI label. However, you cannot boot a system from an EFI-labeled disk.
After the Solaris release is installed on a system with an EFI-labeled disk, the partition table appears similar to the following:
Current partition table (original):
Total disk sectors available: 2576924638 + 16384 (reserved sectors)
Part      Tag    Flag     First Sector          Size          Last Sector
  0       root    wm                34         1.20TB           2576924636
  1 unassigned    wm                 0            0                0
  2 unassigned    wm                 0            0                0
  3 unassigned    wm                 0            0                0
  4 unassigned    wm                 0            0                0
  5 unassigned    wm                 0            0                0
  6 unassigned    wm                 0            0                0
  8   reserved    wm        2576924638         8.00MB           2576941021
Managing Disks With EFI Disks Labels
Use the following table to locate information on managing disks with EFI disk labels.
Task
For More Information
If the system is already installed, connect the disk to the system and perform a reconfiguration boot.
SPARC: Adding a System Disk or a Secondary Disk (Task Map) or x86: Adding a System Disk or a Secondary Disk (Task Map)
Repartition the disk by using the format utility, if necessary.
SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk
Create disk volumes, and if needed, create soft partitions by using Solaris Volume Manager. Or, set up a ZFS storage pool.
Chapter 2, Storage Management Concepts, in Solaris Volume Manager Administration Guide or Creating a ZFS Storage Pool in Oracle Solaris ZFS Administration Guide
Create UFS file systems for the new disk by using the newfs command.
SPARC: How to Create a UFS File System or x86: How to Create File Systems
Or, create a ZFS file system.
How to Create ZFS File Systems in Oracle Solaris ZFS Administration Guide
Clone a disk with an EFI label
Example 28–2
Troubleshooting Problems With EFI Disk Labels
Use the following error messages and solutions to troubleshoot problems with EFI-labeled disks.
Error Message
Dec  3 09:26:48 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/
sf@1,0/ssd@w50020f23000002a4,0 (ssd1):
Dec  3 09:26:48 holoship disk has 2576941056 blocks, which is too large
for a 32-bit kernel
Cause
You attempted to boot a system running a 32-bit SPARC or x86 kernel with a disk greater than 1 terabyte.
Solution
Boot a system running a 64-bit SPARC or x86 kernel with a disk greater than 1 terabyte.
Error Message
Dec  3 09:12:17 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/
Dec  3 09:12:17 holoship corrupt label - wrong magic number
Cause
You attempted to add a disk to a system running an older Solaris release.
Solution
Add the disk to a system running the Solaris release that supports the EFI disk label.
