System Administration Guide: Devices and File Systems
Guidelines for Using the format Utility
Table 10–5 format Utility Guidelines
Task
Guidelines
For More Information
Format a disk.
  • Any existing data is destroyed when you reformat a disk.
  • The need for formatting a disk drive has decreased as more and more manufacturers ship their disk drives formatted and partitioned. You might not need to use the format utility when you add a disk drive to an existing system.
  • If a disk has been relocated and is displaying many disk errors, you can attempt to reformat it. Reformatting automatically remaps any bad sectors.
How to Format a Disk
Replace a system disk.
  • Data from the damaged system disk must be restored from a backup medium. Otherwise, the system will have to be reinstalled by using the installation utility.
SPARC: How to Connect a System Disk and Boot, x86: How to Connect a System Disk, or, if the system must be reinstalled, Oracle Solaris 10 9/10 Installation Guide: Basic Installations
Divide a disk into slices.
  • Any existing data is destroyed when you repartition and relabel a disk with existing slices.
  • Existing data must be copied to backup media before the disk is repartitioned and restored.
SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk
Add a secondary disk to an existing system.
  • Any existing data must be restored from backup media if the secondary disk is reformatted or repartitioned.
SPARC: How to Connect a Secondary Disk and Boot or x86: How to Connect a Secondary Disk and Boot
Repair a disk drive.
  • Some customer sites prefer to replace rather than repair defective drives. If your site has a repair contract with the disk drive manufacturer, you might not need to use the format utility to repair disk drives.
  • The repair of a disk drive usually means that a bad sector is added to a defect list. New controllers remap bad sectors with no system interruption.
  • If the system has an older controller, you might need to remap a bad sector and restore any lost data.
Repairing a Defective Sector
