Use the following table to locate information on managing disks with EFI disk labels.
Task |
For More Information |
If the system is already installed, connect the disk to the system and perform a reconfiguration boot. |
SPARC: Adding a System Disk or a Secondary Disk (Task Map) or x86: Adding a System Disk or a Secondary Disk (Task Map) |
Repartition the disk by using the format utility, if necessary. |
SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk |
Create disk volumes, and if needed, create soft partitions by using Solaris Volume Manager. Or, set up a ZFS storage pool. |
Chapter 2, Storage Management Concepts, in Solaris Volume Manager Administration Guide or Creating a ZFS Storage Pool in Oracle Solaris ZFS Administration Guide |
Create UFS file systems for the new disk by using the newfs command. |
SPARC: How to Create a UFS File System or x86: How to Create File Systems |
Or, create a ZFS file system. |
How to Create ZFS File Systems in Oracle Solaris ZFS Administration Guide |
Clone a disk with an EFI label |
