System Administration Guide: Devices and File Systems
Recommendations and Requirements for Using the format Utility
You must be superuser or have assumed an equivalent role to use the format utility. Otherwise, the following error message is displayed when you try to use the format utility:
$ format
Searching for disks...done
No permission (or no disks found)!
Keep the following guidelines in mind when you use the format utility and want to preserve the existing data:
