System Administration Guide: Devices and File Systems
Repairing a Defective Sector
If a disk on your system has a defective sector, you can repair the disk by following procedures in this section. You might become aware of defective sectors when you do the following:
ProcedureHow to Identify a Defective Sector by Using Surface Analysis
  1. Become superuser or assume an equivalent role.
  2. Unmount the file system in the slice that contains the defective sector.
    # umount /dev/dsk/device-name
    For more information, see mount(1M).
  3. Invoke the format utility.
    # format
  4. Select the affected disk.
    Specify disk (enter its number):1
    selecting c0t2d0:
    [disk formatted]
    Warning: Current Disk has mounted partitions.
  5. Select the analyze menu.
    format> analyze
  6. Set up the analysis parameters by typing setup at the analyze> prompt.
    Use the parameters shown here:
    analyze> setup
    Analyze entire disk [yes]? n
    Enter starting block number [0, 0/0/0]: 12330
    Enter ending block number [2052287, 2035/13/71]: 12360
    Loop continuously [no]? y
    Repair defective blocks [yes]? n
    Stop after first error [no]? n
    Use random bit patterns [no]? n
    Enter number of blocks per transfer [126, 0/1/54]: 1
    Verify media after formatting [yes]? y
    Enable extended messages [no]? n
    Restore defect list [yes]? y
    Create defect label [yes]? y
  7. Find the defect by using the read command.
    analyze> read
    Ready to analyze (won't harm SunOS). This takes a long time,
    but is interruptible with Control-C. Continue? y
            pass 0
       2035/12/1825/7/24
            pass 1
    Block 12354  (18/4/18), Corrected media error (hard data ecc)
       25/7/24
    ^C
    Total of 1 defective blocks repaired.
ProcedureHow to Repair a Defective Sector
  2. Invoke the format utility.
    # format
  3. Select the disk that contains the defective sector.
    Specify disk (enter its number): 1
    selecting c0t3d0
    [disk formatted]
    format>
  4. Select the repair command.
    format> repair
  5. Type the defective block number.
    Enter absolute block number of defect: 12354
       Ready to repair defect, continue? y
       Repairing block 12354 (18/4/18)...ok.
    format>
    If you are unsure of the format that is used to identify the defective sector, see How to Identify a Defective Sector by Using Surface Analysis for more information.
