System Administration Guide: Devices and File Systems
ProcedureSPARC: How to Install a Boot Block on a System Disk
  1. Become superuser or assume an equivalent role.
  2. Install a boot block on the system disk.
    For a UFS root file system:
    # installboot /usr/platform/`uname -i`/lib/fs/ufs/bootblk
    /dev/rdsk/cwtxdys0
    /usr/platform/`uname -i`/lib/fs /ufs/bootblk
    Is the boot block code.
    /dev/rdsk/cwtxdys0
    Is the raw device of the root (/) file system.
    For a ZFS root file system:
    # installboot -F zfs /usr/platform/`uname -i`/lib/fs/zfs/bootblk
    /dev/rdsk/cwtxdys0
    /dev/rdsk/cwtxdys0
    For more information, see installboot(1M).
  3. Verify that the boot blocks are installed by rebooting the system to run level 3.
    # init 6
Example 12–3 SPARC: Installing a Boot Block on a System Disk
The following example shows how to install the boot block on a UFS root file system.
# installboot /usr/platform/sun4u/lib/fs/ufs/bootblk
/dev/rdsk/c0t0d0s0
The following example shows how to install the boot block on a ZFS root file system.
# installboot -F zfs /usr/platform/`uname -i`/lib/fs/zfs/bootblk /dev/rdsk/c0t1d0s0
