System Administration Guide: Devices and File Systems
ProcedureHow to Mount a CacheFS File System (/etc/vfstab)
  1. Become superuser on the client system.
  2. Using an editor, specify the file systems to be mounted in the /etc/vfstab file.
    See the example that follows.
    For more information on the /etc/vfstab file, see Field Descriptions for the /etc/vfstab File.
  3. Mount the CacheFS file system.
    # mount /mount-point
    Or, reboot the system.
Example 19–3 Mounting a CacheFS File System (/etc/vfstab)
The following example shows the /etc/vfstab entry for the /data/abc directory from the remote system starbug that is mounted in the cached directory, /opt/cache.
#device           device             mount      FS     fsck  mount   mount
#to mount         to fsck            point      type   pass  at boot options
starbug:/data/abc /local/abc         /opt/cache cachefs 7    yes     local-access,bg,
