System Administration Guide: Devices and File Systems
Collecting CacheFS Statistics (Task Map)
The following task map shows the steps involved in collecting CacheFS statistics. All these procedures are optional.
Task
Description
For Instructions
Set up logging.
Set up logging on a CacheFS file system by using the cachefslog command.
How to Set Up CacheFS Logging
Locate the log file.
Locate the log file by using the cachefslog command.
How to Locate the CacheFS Log File
Stop logging.
Stop logging by using the cachefslog command.
How to Stop CacheFS Logging
View the cache size.
View the cache size by using the cachefswssize command.
How to View the Working Set (Cache) Size
View the cache statistics.
View the statistics by using the cachefsstat command.
How to View CacheFS Statistics
