Become superuser or assume an equivalent role.
Mount a file system listed in the /etc/vfstab file.
# mount /mount-point |
where /mount-point specifies an entry in the mount point or device to mount field in the /etc/vfstab file. It is usually easier to specify the mount point.
The following example shows how to mount the /usr/dist file system that is listed in the /etc/vfstab file.
# mount /usr/dist |
The following example shows the messages that are displayed when you use the mountall command and the file systems are already mounted.
# mountall /dev/rdsk/c0t0d0s7 already mounted mount: /tmp already mounted mount: /dev/dsk/c0t0d0s7 is already mounted, /export/home is busy, or the allowable number of mount points has been exceeded |
When using the mountall command, all the file systems with a device to fsck entry are checked and fixed, if necessary, before they are mounted.
The following example shows how to mount all the local systems that are listed in the /etc/vfstab file.
# mountall -l # mount / on /dev/dsk/c0t0d0s0 read/write/setuid/intr/largefiles/xattr/onerror=... /devices on /devices read/write/setuid/dev=46c0000 on Thu Sep ... /system/contract on ctfs read/write/setuid/devices/dev=43c0001 ... /usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/... /proc on /proc read/write/setuid/dev=4700000 on Thu Sep 2 ... /etc/mnttab on mnttab read/write/setuid/dev=47c0000 on Thu Sep 2 ... /etc/svc/volatile on swap read/write/setuid/devices/xattr/dev=4480001 ... /system/object on objfs read/write/setuid/devices/dev=44c0001 ... /dev/fd on fd read/write/setuid/dev=4800000 on Thu Sep 2 ... /var/run on swap read/write/setuid/xattr/dev=1 on Thu Sep 2 ... /tmp on swap read/write/setuid/xattr/dev=2 on Thu Sep 2 ... /stuff on /dev/dsk/c0t0d0s5 read/write/setuid/intr/largefiles/xattr... /export/home on /dev/dsk/c0t0d0s7 read/write/setuid/intr/largefiles/... |
The following example shows how to mount all available ZFS file systems.
# zfs mount -a |
The following example shows how to mount all the remote file systems that are listed in the /etc/vfstab file.
# mountall -r # mount / on /dev/dsk/c0t0d0s0 read/write/setuid/intr/largefiles/xattr/onerror=... /devices on /devices read/write/setuid/dev=46c0000 on Thu Sep ... /system/contract on ctfs read/write/setuid/devices/dev=43c0001 ... /usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/... /proc on /proc read/write/setuid/dev=4700000 on Thu Sep 2 ... /etc/mnttab on mnttab read/write/setuid/dev=47c0000 on Thu Sep 2 ... /etc/svc/volatile on swap read/write/setuid/devices/xattr/dev=4480001 ... /system/object on objfs read/write/setuid/devices/dev=44c0001 ... /dev/fd on fd read/write/setuid/dev=4800000 on Thu Sep 2 ... /var/run on swap read/write/setuid/xattr/dev=1 on Thu Sep 2 ... /tmp on swap read/write/setuid/xattr/dev=2 on Thu Sep 2 ... /stuff on /dev/dsk/c0t0d0s5 read/write/setuid/intr/largefiles/xattr... /stuff on /dev/dsk/c0t0d0s5 read/write/setuid/intr/largefiles/xattr... /export/home on /dev/dsk/c0t0d0s7 read/write/setuid/intr/largefiles/... /home/rimmer on pluto:/export/home/rimmer remote/read/write/setuid/xattr/... |
