System Administration Guide: Devices and File Systems
ProcedureHow to Unmount a File System
Use the following procedure to unmount a file system, except for the root (/), /usr, or /var file systems.
Note –
The root (/), /usr, and /var file systems can be unmounted only during a shutdown. The system needs these file systems to function.
  1. Ensure that you have met the prerequisites listed in Prerequisites for Unmounting File Systems.
  2. Unmount the file system.
    # umount /mount-point
    where /mount-point is the name of the file system that you want to unmount. This can be one of the following:
    • The directory name where the file system is mounted
    • The device name path of the file system
    • The resource for an NFS file system
    • The loopback directory for an LOFS file system
Example 18–10 Unmounting a File System
The following example shows how to unmount a local UFS home file system.
# umount /export/home
The following example shows how to unmount the UFS file system on slice 7.
# umount /dev/dsk/c0t0d0s7
The following example shows how to forcibly unmount the UFS /export file system.
# umount -f /export
The following example shows how to unmount all UFS file systems in the /etc/vfstab file, except for the root (/), /proc, /var, and /usr file systems.
# umountall
The following example shows to unmount all ZFS file systems.
# zfs umount -a
All file systems are unmounted, except for those file systems that are busy.
