System Administration Guide: Devices and File Systems
ProcedureHow to Stop All Processes Accessing a File System
  1. Become superuser or assume an equivalent role.
  2. List all the processes that are accessing the file system so that you know which processes you are going to stop.
    # fuser -c [ -u ] /mount-point
    -c
    Reports on files that are mount points for file systems and any files within those mounted file systems.
    -u
    Displays the user login name for each process ID.
    /mount-point
    Specifies the name of the file system for which you want to stop processes.
  3. Stop all processes that are accessing the file system.
    # fuser -c -k /mount-point
    A SIGKILL is sent to each process that is using the file system.
    Note –
    You should not stop a user's processes without first warning the user.
  4. Verify that no processes are accessing the file system.
    # fuser -c /mount-point
Example 18–9 Stopping All Processes Accessing a File System
The following example shows how to stop process 4006c that is using the /export/home file system.
# fuser -c /export/home
/export/home:     4006c
# fuser -c -k /export/home
/export/home:     4006c
/export/home:
