System Administration Guide: Devices and File Systems
Commands for UFS File System Administration
Most commands for file system administration have both a generic component and a file system–specific component. Whenever possible, you should use the generic commands, which call the file system–specific component. The following table lists the generic commands for file system administration. These commands are located in the /usr/sbin directory.
Table 16–1 Generic Commands for File System Administration
Command
Description
Man Page
clri
Clears inodes
clri(1M)
df
Reports the number of free disk blocks and files
df(1M)
ff
Lists file names and statistics for a file system
ff(1M)
fsck
Checks the integrity of a file system and repairs any damage found
fsck(1M)
fsdb
Debugs the file system
fsdb(1M)
fstyp
Determines the file system type
fstyp(1M)
labelit
Lists or provides labels for file systems when they are copied to tape (for use only by the volcopy command)
labelit(1M)
mkfs
Creates a new file system
mkfs(1M)
mount
Mounts local and remote file systems
mount(1M)
mountall
Mounts all file systems that are specified in the virtual file system table (/etc/vfstab)
mountall(1M)
ncheck
Generates a list of path names with their inode numbers
ncheck(1M)
umount
Unmounts local and remote file systems
mount(1M)
umountall
Unmounts all file systems that are specified in the virtual file system table (/etc/vfstab)
mountall(1M)
volcopy
Creates an image copy of a file system
volcopy(1M)
How File System Commands Determine the File System Type
The generic file system commands determine the file system type by following this sequence:
  1. From the -F option, if supplied.
  2. By matching a special device with an entry in the /etc/vfstab file (if the special device is supplied). For example, fsck first looks for a match against the fsck device field. If no match is found, the command then checks the special device field.
  3. By using the default specified in the /etc/default/fs file for local file systems and in the /etc/dfs/fstypes file for remote file systems.
Manual Pages for Generic and Specific File System Commands
Both the generic commands and specific commands have manual pages in the man pages section 1M: System Administration Commands. The manual pages for the generic file system commands provide information about generic command options only. The manual page for a specific file system command has information about options for that file system. To look at a manual page for a specific file system, append an underscore and the abbreviation for the file system type to the generic command name.
For example, to see the specific manual page for mounting a UFS file system, type the following:
$ man mount_ufs
For example, to see the specific manual page for mounting a ZFS file system, type the following:
$ man zfs
