System Administration Guide: Devices and File Systems
ProcedureHow to Remove Unneeded Swap Space
  1. Become superuser.
  2. Remove the swap space.
    # /usr/sbin/swap -d /path/filename
    The swap file name is removed so that it is no longer available for swapping. The file itself is not deleted.
  3. Edit the /etc/vfstab file and delete the entry for the swap file.
  4. Recover the disk space so that you can use it for something else.
    # rm /path/filename
    If the swap space is a file, remove it. Or, if the swap space is on a separate slice and you are sure you will not need it again, make a new file system and mount the file system.
    For information on mounting a file system, see Chapter 18, Mounting and Unmounting File Systems (Tasks).
  5. Verify that the swap file is no longer available.
    # swap -l
Example 20–2 Removing Unneeded Swap Space
The following examples shows how to delete the /files/swapfile swap file.
# swap -d /files/swapfile
# (Remove the swap entry from the /etc/vfstab file)
# rm /files/swapfile
# swap -l
swapfile             dev  swaplo  blocks   free
/dev/dsk/c0t0d0s1   136,1      16 1638608 1600528
