System Administration Guide: Devices and File Systems
Adding More Swap Space
As system configurations change and new software packages are installed, you might need to add more swap space. The easiest way to add more swap space is to use the mkfile and swap commands to designate a part of an existing UFS or NFS file system as a supplementary swap area. These commands, described in the following sections, enable you to add more swap space without repartitioning a disk.
Alternative ways to add more swap space are to repartition an existing disk or to add another disk. For information on how to repartition a disk, see Chapter 10, Managing Disks (Overview).
Creating a Swap File in a UFS Root Environment
You can create a swap file to be used in a UFS root file system. Swap files are currently not supported in a ZFS root environment. The following general steps are involved in creating a swap file:
mkfile Command
The mkfile command creates a file that is suitable for use as either an NFS-mounted swap area or a local swap area. The sticky bit is set, and the file is filled with zeros. You can specify the size of the swap file in bytes (the default) or in KB, blocks, or MB by using the k, b, or m suffixes, respectively.
The following table shows the mkfile command options.
Table 20–2 Options to the mkfile Command
Creates an empty file. The size is noted. However, the disk blocks are not allocated until data is written to them.
Reports the names and sizes of created files.
Note –
Use the -n option only when you create an NFS swap file.
ProcedureHow to Create a Swap File and Make It Available in UFS Root Environment
  1. Become superuser.
    You can create a swap file without root permissions. However, to avoid accidental overwriting, root should be the owner of the swap file.
  2. Create a directory for the swap file, if needed.
  3. Create the swap file.
    # mkfile nnn[k|b|m] filename
    The swap file of the size nnn (in KB, bytes, or MB) with the filename you specify is created.
  4. Activate the swap file.
    # /usr/sbin/swap -a /path/filename
    You must use the absolute path name to specify the swap file. The swap file is added and available until the file system is unmounted, the system is rebooted, or the swap file is removed. Keep in mind that you cannot unmount a file system while some process or program is swapping to the swap file.
  5. Add an entry for the swap file to the /etc/vfstab file that specifies the full path name of the file, and designates swap as the file system type.
    /path/filename   -      -       swap     -     no     -
  6. Verify that the swap file is added.
    $ /usr/sbin/swap -l
    Note –
    If a swap file does not get activated, make sure that the following service is running:
    # svcs nfs/client
    STATE          STIME    FMRI
    enabled        14:14:34 svc:/network/nfs/client:default
Example 20–1 Creating a Swap File and Making It Available in a UFS Root Environment
The following examples shows how to create a 100-MB swap file called /files/swapfile.
# mkdir /files
# mkfile 100m /files/swapfile
# swap -a /files/swapfile
# vi /etc/vfstab
(An entry is added for the swap file):
/files/swapfile   -      -       swap     -     no     -
# swap -l
swapfile             dev  swaplo blocks   free
/dev/dsk/c0t0d0s1   136,1      16 1638608 1600528
/files/swapfile        -       16 204784  204784
