System Administration Guide: Devices and File Systems
Syntax and Options for the fsck Command
The fsck command checks and repairs inconsistencies in file systems. If you run the fsck command without any options, it interactively asks for confirmation before making repairs. This command has four options.
Command and Option
fsck -m
Checks whether a file system can be mounted
fsck -y
Assumes a yes response for all repairs
fsck -n
Assumes a no response for all repairs
fsck -o p
Noninteractively preens the file system, fixing all expected (innocuous) inconsistencies, but exits when a serious problem is encountered
