System Administration Guide: Devices and File Systems
ProcedureHow to Preen a UFS File System
This procedure assumes that the file system is unmounted or inactive.
  1. Become superuser or assume an equivalent role.
  2. Unmount the UFS file system.
    # umount /mount-point
  3. Check the UFS file system with the preen option.
    # fsck -o p /dev/rdsk/device-name
    You can preen individual file systems by using /mount-point or /dev/rdsk/device-name as arguments to the fsck command.
Example 21–2 Preening a UFS File System
The following example shows how to preen the /export/home file system.
# fsck -o p /export/home
