System Administration Guide: Devices and File Systems
ProcedureHow to Eject Removable Media
  1. Ensure that the media is not being used.
    Remember, media is “being used” if a shell or an application is accessing any of its files or directories. If you are not sure whether you have found all users of a DVD (for example, a shell hidden behind a desktop tool might be accessing it), use the fuser command. See How to Determine If Removable Media Is Still in Use.
  2. Eject the media.
    # eject media
    For example, for a DVD, you would do the following:
    # eject cdrom
    For example, for a USB memory stick, you would do the following:
    # eject rmdisk0
    Tip –
    You can view the removable device name with the eject -l command.
