System Administration Guide: Devices and File Systems
Accessing Removable Media
You can access information on removable media with or without using volume management. For information on accessing information on removable media with GNOME's File Manager, see the GNOME desktop documentation.
Volume management (vold) actively manages all removable media devices. So, any attempt to access removable media with device names such as /dev/rdsk/cntndnsn or /dev/dsk/cntndnsn will be unsuccessful.
Using Removable Media Names
You can access all removable media with different names. The following table describes the different media names that can be accessed with or without volume management.
Table 3–1 Removable Media Names
Media
Volume Management Device Name
Volume Management Device Alias Name
Device Name
First diskette drive
/floppy
/vol/dev/aliases/floppy0
/dev/rdiskette
/vol/dev/rdiskette0/
volume-name
First, second, third CD-ROM or DVD-ROM drives
/cdrom0
/cdrom1
/cdrom2
/vol/dev/aliases/cdrom0
/vol/dev/aliases/cdrom1
/vol/dev/aliases/cdrom2
/vol/dev/rdsk/cntn[dn]/
volume-name
USB memory stick
/rmdisk/noname
/vol/dev/aliases/rmdisk0
/vol/dev/dsk/cntndn/volume-name:c
Guidelines for Accessing Removable Media Data
Most CDs and DVDs are formatted to the ISO 9660 standard, which is portable. So, most CDs and DVDs can be mounted by volume management. However, CDs or DVDs with UFS file systems are not portable between architectures. So, they must be used on the architecture for which they were designed.
For example, a CD or DVD with a UFS file system for a SPARC platform cannot be recognized by an x86 platform. Likewise, an x86 UFS CD cannot be mounted by volume management on a SPARC platform. The same limitation generally applies to diskettes. However, some architectures share the same bit structure, so occasionally a UFS format specific to one architecture will be recognized by another architecture. Still, the UFS file system structure was not designed to guarantee this compatibility.
To accommodate the different formats, the CD or DVD is split into slices. Slices are similar in effect to partitions on hard disks. The 9660 portion is portable, but the UFS portion is architecture-specific. If you are having trouble mounting a CD or DVD, particularly if it is an installation CD or DVD, make sure that its UFS file system is appropriate for your system's architecture. For example, you can check the label on the CD or DVD.
ProcedureHow to Add a New Removable Media Drive
Generally, most modern bus types support hot-plugging. If your system's bus type supports hot-plugging, you might only need to do step 5 below. If your system's bus type does not support hot-plugging, you might have to do the following tasks, which are described in steps 1-6 below.
For more information about hot-plugging devices, see Chapter 6, Dynamically Configuring Devices (Tasks).
  1. Become superuser.
  2. Create the /reconfigure file.
    # touch /reconfigure
  3. Bring the system to run level 0.
    # init 0
  4. Turn off power to the system.
  5. Connect the new media drive.
    See your hardware handbook for specific instructions.
  6. Turn on power to the system.
    The system automatically comes up to multiuser mode.
ProcedureHow to Disable or Enable Removable Media Services
Occasionally, you might want to manage media without using removable media services. This section describes how to disable and enable removable media services.
Disabling these services means that you would have to mount all media manually by using the mount command.
  1. Ensure that the media is not being used.
    If you are not sure whether you have found all users of the media, use the fuser command, see How to Determine If Removable Media Is Still in Use.
  2. Become superuser.
  3. Select one of the following:
    • Disable removable media services.
      # svcadm disable volfs
    • Enable removable media services.
      # svcadm enable volfs
      volume management starting.
ProcedureHow to Access Information on Removable Media
  1. Insert the media.
    The media is mounted after a few seconds.
  2. List the contents of the media.
    % ls /media
    Use the appropriate device name to access information by using the command-line interface. See Table 3–1 for an explanation of device names.
Example 3–1 Accessing Information on Removable Media
This example shows how to access information on a diskette.
$ ls /floppy
myfile
This example shows how to access information on a USB memory stick.
$ ls /rmdisk
rmdisk0/		rmdisk1/
This example shows how to access information on a DVD.
$ ls /cdrom
cdrom0             sol_10_910_sparc
ProcedureHow to Copy Information From Removable Media
You can access files and directories on removable media as with any other file system. The only significant restrictions are related to ownership and permissions.
For instance, if you copy a file from a DVD into your file system, you are the owner. However, you won't have write permissions because the file on the DVD never had them. You must change the permissions yourself.
  1. Ensure that the media is mounted.
    $ ls /media
    The ls command displays the contents of a mounted media. If no contents are displayed, see How to Access Information on Removable Media.
  2. (Optional) Copy the files or directories.
    For example, for a DVD, you would do the following:
    $ cp /cdrom/sol_10_910_sparc/Solaris_10/Tools/add_install_client .
    $ ls -l
    -rwxr-xr-x   1 pmorph	  gelfs   64065 Jul 12  2010 add_install_client
ProcedureHow to Determine If Removable Media Is Still in Use
  2. Identify the processes that are accessing the media.
    # fuser -u /media
    The -u displays the user of the media.
    For more information, see fuser(1M).
  3. (Optional) Kill the process accessing the media.
    # fuser -u -k /media
    The -k kills the processes accessing the media.
    Caution – Caution –
    Killing the processes that are accessing the media should only be used in emergency situations.
  4. Verify that the process is gone.
    # pgrep process-ID
Example 3–2 Determining If the Media Is Still in Use
The following example shows that the user pmorph, is accessing the /cdrom/sol_10_910_sparc/Solaris_10/Tools directory.
# fuser -u /cdrom/sol_10_910_sparc/Solaris_10/Tools
/cdrom/sol_910_sparc/Solaris_10/Tools:      902c(pmorph)     339c(pmorph)
ProcedureHow to Eject Removable Media
    Remember, media is “being used” if a shell or an application is accessing any of its files or directories. If you are not sure whether you have found all users of a DVD (for example, a shell hidden behind a desktop tool might be accessing it), use the fuser command. See How to Determine If Removable Media Is Still in Use.
  2. Eject the media.
    # eject media
    # eject cdrom
    For example, for a USB memory stick, you would do the following:
    # eject rmdisk0
    Tip –
    You can view the removable device name with the eject -l command.
