System Administration Guide: Devices and File Systems
ProcedureHow to Extract an Audio Track on a CD
Use the following procedure to extract an audio track from a CD and copy the audio track to a new CD.
If you don't use the cdrw -T option to specify the audio file type, the cdrw command uses the filename extension to determine the audio file type. For example, the cdrw command detects that this file is a .wav file.
$ cdrw -x 1 testme.wav
  1. Insert an audio CD into the CD-RW drive.
  2. Extract an audio track.
    $ cdrw -x -T audio-type 1 audio-file
    -x
    Extracts audio data from an audio CD.
    T audio-type
    Identifies the type of audio file to be extracted. Supported audio types are sun, wav, cda, or aur.
    audio-file
    Identifies the audio track to be extracted.
  3. Copy the track to a new CD.
    $ cdrw -a audio-file
Example 4–3 Extracting and Creating Audio CDs
The following example shows how to extract the first track from an audio CD and name the file song1.wav.
$ cdrw -x -T wav 1 song1.wav
Extracting audio from track 1...done.
This example shows how to copy a track to an audio CD.
$ cdrw -a song1.wav
Initializing device...done.
Writing track 1...done.
Finalizing (Can take several minutes)...done.
