You can use the cdrw command to create audio CDs from individual audio tracks or from .au and .wav files.
The supported audio formats are describes in the following table:
Format |
Description |
sun |
Sun .au file with data in Red Book CDDA format |
wav |
RIFF (.wav) file with data in Red Book CDDA format |
cda |
.cda file with raw CD audio data, which is 16-bit PCM stereo at 44.1 kHz sample rate in little-endian byte order |
aur |
.aur files with raw CD data in big-endian byte order |
If no audio format is specified, the cdrw command tries to determine the audio file format based on the file extension. The case of the characters in the extension is ignored.
