System Administration Guide: Devices and File Systems
Chapter 1 Managing Removable Media (Overview)
This chapter provides general guidelines for managing removable media in the Solaris OS.
This is a list of the overview information in this chapter.
What's New in Removable Media?
The following section describes new removable media features in the Solaris release.
For a complete listing of new Solaris features and a description of Solaris releases, see Oracle Solaris 10 9/10 What’s New.
vold is Managed by the Service Management Facility (SMF)
Solaris 10 1/06: The volume management daemon, vold, is now managed by the Service Management Facility (SMF). This means you can use the svcadm disable command to disable the following new volfs service, if appropriate:
# svcadm disable volfs
You can identify the status of the volfs service by using this command:
$ svcs volfs
STATE          STIME    FMRI
online         Sep_29   svc:/system/filesystem/volfs:default
For more information, see smf(5).
You can use the svccfg command to display and to set additional vold properties. For example, you could temporarily enable vold logging to help troubleshooting a problem. For example:
# svccfg
svc:> select system/filesystem/volfs
svc:/system/filesystem/volfs> setprop vold/log_debuglevel=3
svc:/system/filesystem/volfs> exit
# svcadm enable volfs
You can also use the svccfg command to display a listing of settable vold properties.
# svccfg
svc:> select volfs
svc:/system/filesystem/volfs> listprop vold/*
vold/config_file            astring
vold/log_debuglevel         count    3
vold/log_file               astring
vold/log_nfs_trace          boolean  false
vold/log_verbose            boolean  false
vold/root_dir               astring
vold/never_writeback_label  boolean  false
For a description of these properties, see the vold(1M).
Improvements to Volume Management (vold)
Solaris 10 1/06: Removable media management is improved. Previously, vold did not create device links for removable devices that contain no media. Now, device links are properly created for devices that contain no media, similar to the following:
lrwxrwxrwx   1 root     root     28 Jun 13 13:09 /vol/dev/aliases/cdrom0 ->
 /vol/dev/rdsk/c2t2d0/nomedia
Now, you can use the cdrw and rmformat commands to list devices that have no media when vold is running.
You can revert back to the previous vold behavior by changing the following support nomedia entry in the /etc/vold.conf file as follows:
support media
Then, restart vold. For more information, see vold.conf(4).
In addition, vold is now hot-plug aware. This improvement means that if you insert removable media, the media is automatically detected and mounted by vold. There should be no need to restart vold manually to recognize and mount a file system from any removable media device.
If you are using a legacy or non-USB diskette device, then you might need to issue the volcheck command before vold can recognize the media.
If the media is detected, but for some reason, is unmounted, then you'll need to run the following commands:
# volrmmount -i rmdisk0
Before you hot-remove a removable media device, eject the media first. For example:
# eject rmdisk0
Where to Find Managing Removable Media Tasks
Use these references to find step-by-step instructions for managing removable media.
Removable Media Management Task
For More Information
Access removable media
Chapter 3, Accessing Removable Media (Tasks)
Format removable media
Chapter 2, Managing Removable Media (Tasks)
Write data CDs and DVDs and music CDs
Chapter 4, Writing CDs and DVDs (Tasks)
Removable Media Features and Benefits
The Solaris release gives users and software developers a standard interface for dealing with removable media. Removable media services provide the following benefits:
Comparison of Manual and Automatic Mounting
The following table compares the steps involved in manual mounting (without removable media services) and automatic mounting (with removable media management) of removable media.
Table 1–1 Comparison of Manual and Automatic Mounting of Removable Media
Steps
Manual Mounting
Automatic Mounting
Insert media.
Insert media.
Become superuser.
For diskettes, use the volcheck command.
Determine the location of the media device.
Removable media services automatically perform many of the tasks that are required to manually mount and work with removable media.
Create a mount point.
Make sure you are not in the mount point directory.
Mount the device and use the proper mount options.
Exit the superuser account.
Work with files on media.
Become superuser.
10
Unmount the media device.
11
Eject media.
Eject media.
12
Overview of Accessing Removable Media
Essentially, removable media services enable you to access removable media just as manual mounting does, but more easily and without the need for superuser access.
If your system has more than one type of removable device, see the following table for their access points.
Table 1–2 How to Access Data on Removable Media
Access
Insert
Find the Files Here
Files on the first diskette
The diskette and type volcheck on the command line
/floppy
Files on the removable hard disk
The removable hard disk and type volcheck on the command line
/rmdisk/rmdisk0 or /rmdisk/rmdisk1
Files on the first CD
The CD and wait for a few seconds
/cdrom/volume-name
Files on the first DVD
The DVD and wait for a few seconds
/cdrom/volume-name
Table 1–3 Where to Access Removable Media
Access File Systems With This Path
Access Raw Data With This Path
/floppy/floppy0
/vol/dev/aliases/floppy0
/floppy/floppy1
/vol/dev/aliases/floppy1
/cdrom/cdrom0
/cdrom/cdrom1
/vol/dev/aliases/cdrom1
/rmdisk/rmdisk0 or
/rmdisk/rmdisk1
/vol/dev/aliases/rmdisk0 or
/vol/dev/aliases/rmdisk1
/pcmem/pcmem0
/vol/dev/aliases/pcmem0
