Solaris 10 Installation Guide: Network-Based Installations
x86: Overview of Booting and Installing Over the Network With PXE
This section provides an overview of the Preboot Execution Environment (PXE).
x86: What is PXE?
PXE network boot is a “direct” network boot. No boot media is required on the client system. With PXE, you can install an x86 based client over the network by using DHCP.
PXE network boot is available only for devices that implement the Intel Preboot Execution Environment specification. To determine if your system supports PXE network boot, see your hardware manufacturer's documentation.
In the Solaris 10 3/05 and earlier releases, the Solaris boot diskette is still available for systems that do not support PXE. The boot diskette image is available on the Solaris 10 Software for x86 Platforms - 2 CD. The Solaris boot diskette is not available in the Solaris 10 2/06 release.
x86: Guidelines for Booting With PXE
To boot over the network by using PXE, you need the following systems.
When you are preparing to use PXE to install a client over the network, consider the following issues.
