SPARC: You cannot use a system that is running a SunOS version that was released prior to the Solaris 2.3 release.
This procedure assumes that the system is running the Volume Manager. If you are not using the Volume Manager to manage media, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without the Volume Manager.
On the SPARC system that is to become the install server, become superuser.
The system must include a DVD-ROM drive and be part of the site's network and name service. If you use a name service, the system must already be in a service, such as NIS, NIS+, DNS, or LDAP. If you do not use a name service, you must distribute information about this system by following your site's policies.
Insert the Solaris 10 DVD in the SPARC system's drive.
Create a directory to contain the DVD image.
# mkdir -p install_dir_path |
Change to the Tools directory on the mounted disc.
For SPARC DVD media, type:
# cd /cdrom/cdrom0/s0/Solaris_10/Tools |
For x86 DVD media, type:
# cd /cdrom/cdrom0/Solaris_10/Tools |
In the previous examples, cdrom0 is the path to the drive that contains the Solaris OS DVD media.
Copy the DVD image in the drive to the install server's hard disk.
# ./setup_install_server install_dir_path |
Specifies the directory where the DVD image is to be copied
The setup_install_server command indicates whether you have enough disk space available for the Solaris 10 Software disc images. To determine available disk space, use the df -kl command.
Decide if you need to make the install server available for mounting.
If the install server is on the same subnet as the system to be installed or you are using DHCP, you do not need to create a boot server. Proceed to Step 7.
If the install server is not on the same subnet as the system to be installed and you are not using DHCP, complete the following steps.
Verify that the path to the install server's image is shared appropriately.
# share | grep install_dir_path |
Specifies the path to the installation image where the DVD image was copied
If the path to the install server's directory is displayed and anon=0 is displayed in the options, proceed to Step 7.
If the path to the install server's directory is not displayed or you do not have anon=0 in the options, continue.
Make the install server available to the boot server by adding this entry to the /etc/dfs/dfstab file.
share -F nfs -o ro,anon=0 -d "install server directory" install_dir_path |
Verify that the nfsd daemon is running.
If the install server is running the Solaris 10 OS, or compatible version, type the following command.
# svcs -l svc:/network/nfs/server:default |
If the nfsd daemon is online, continue to Step d. If the nfsd daemon is not online, start it.
# svcadm enable svc:/network/nfs/server |
If the install server is running the Solaris 9 OS, or compatible version, type the following command.
# ps -ef | grep nfsd |
If the nfsd daemon is running, continue to Step d. If the nfsd daemon is not running, start it.
# /etc/init.d/nfs.server start |
Share the install server.
# shareall |
Change directories to root (/).
# cd / |
Eject the Solaris 10 DVD.
(Optional) Patch the files that are located in the miniroot on the net install image that was created by setup_install_server. Patching a file might be necessary if a boot image has problems.
For the Solaris 10 SPARC and Solaris 10 3/05 x86 releases, use the patchadd -C command to patch the files that are located in the miniroot.
# patchadd -C install_dir_path path-to-patch/patch-id |
Specifies the path to the network installation miniroot.
Specifies the path to the patch that you want to add, for example, /var/sadm/spool.
Specifies the patch ID that you want to apply.
Don't use the patchadd -C command unless you have read the Patch README instructions or have contacted your local Sun support office.
Starting with the Solaris 10 1/06 for x86 release, follow these steps to patch an x86 network installation miniroot.
These steps assume that you have a system on your network that is running the Solaris 10 1/06 for x86 release, and that system is accessible over the network.
On a system that is running the Solaris 10 1/06 for x86 release, log in as superuser.
Change to the Tools directory of the installation image you created in Step 5.
# cd install-server-path/install-dir-path/Solaris_10/Tools |
Specifies the path to the install server system on your network, for example, /net/installserver-1.
Create a new installation image, and place that image on the system that is running the Solaris 10 1/06 for x86 release.
# ./setup_install_server remote_install_dir_path |
Specifies the path on the Solaris 10 1/06 for x86 system in which to create the new installation image.
This command creates a new installation image on the Solaris 10 1/06 for x86 system. In order to patch this image, you must temporarily place this image on a system that is running the Solaris 10 1/06 for x86 release.
On the Solaris 10 1/06 for x86 system, unpack the network installation boot archive.
# /boot/solaris/bin/root_archive unpackmedia remote_install_dir_path \ destination_dir |
Specifies the path to the x86 network installation image on the Solaris 10 1/06 for x86 system.
Specifies the path to the directory to contain the unpacked boot archive.
On the Solaris 10 1/06 for x86 system, patch the unpacked boot archive.
# patchadd -C destination_dir path-to-patch/patch-id |
You can specify multiple patches with the patchadd -M option. For more information, see patchadd(1M).
On the Solaris 10 1/06 for x86 system, pack the x86 boot archive.
# /boot/solaris/bin/root_archive packmedia destination_dir \ remote_install_dir_path |
Copy the patched miniroot to the installation image on the install server.
# cp remote_install_dir_path/boot/x86.miniroot \ install-server-path/install_dir_path/boot/x86.miniroot |
Decide if you need to create a boot server.
If you are using DHCP or the install server is on the same subnet as the system to be installed, you do not need to create a boot server. Proceed to Adding Systems to Be Installed From the Network With a DVD Image.
If you are not using DHCP and the install server and the client are on a different subnet, you must create a boot server. Proceed to Creating a Boot Server on a Subnet With a DVD Image.
The following example illustrates how to create an install server by copying the Solaris 10 DVD to the install server's /export/home/dvdsparc directory. This example assumes that the install server is running the Solaris 10 OS.
# mkdir -p /export/home/dvdsparc # cd /cdrom/cdrom0/s0/Solaris_10/Tools # ./setup_install_server /export/home/dvdsparc |
If you need a separate boot server, type these commands:
Add the following path to the /etc/dfs/dfstab file:
share -F nfs -o ro,anon=0 -d "install server directory" /export/home/dvdsparc |
Check if the nfsd daemon is online. If the nfsd daemon is not online, start it and share it.
# svcs -l svc:/network/nfs/server:default # svcadm enable svc:/network/nfs/server # shareall # cd / |
The following example illustrates how to create an install server by copying the Solaris 10 DVD to the install server's /export/home/dvdx86 directory. This example assumes that the install server is running the Solaris 10 OS.
# mkdir -p /export/home/dvdx86 # cd /cdrom/cdrom0/Solaris_10/Tools # ./setup_install_server /export/home/dvdx86 |
share -F nfs -o ro,anon=0 -d "install server directory" /export/home/dvdx86 |
After you set up the install server, you must add the client as an installation client. For information about how to add client systems to install over the network, see To Add Systems to Be Installed From the Network With add_install_client (DVD).
If you are not using DHCP, and your client system is on a different subnet than your install server, you must create a boot server. For more information, see Creating a Boot Server on a Subnet With a DVD Image.
For additional information about the setup_install_server and the add_to_install_server commands, see install_scripts(1M).
