For x86 based systems, you can configure the following information with the display keyword.
Graphics card
Screen size
Color depth
Display resolution
Use the following syntax with the display keyword.
display=graphics_card {size=screen_size depth=color_depth resolution=screen_resolution} |
To set the appropriate values for the display keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the display keyword, and include this line in the sysidcfg file.
For more information, see the kdmconfig(1M)
