Solaris 10 Installation Guide: Network-Based Installations
Chapter 16 WAN Boot (Reference)
This chapter briefly describes the commands and files you use to perform a WAN installation.
WAN Boot Installation Commands
The following tables describe the commands you use to perform a WAN boot installation.
Table 16–1 Preparing the WAN Boot Installation and Configuration Files
Task and Description
Command
Copy the Solaris installation image to install-dir-path, and copy the WAN boot miniroot to wan-dir-path on the install server's local disk.
setup_install_server –w wan-dir-path install-dir-path
Create a Solaris Flash archive that is named name.flar.
  • name is the name of the archive
  • optional-parameters are optional parameters you can use to customize the archive
  • document-root is the path to the document root directory on the install server
  • filename is the name of the archive
flar create – n name [optional-parameters] document-root/flash/filename
Check the validity of the custom JumpStart rules file that is named rules.
./check -r rules
Check the validity of the wanboot.conf file.
  • net-ip is the IP address of the client's subnet.
  • client-ID can be a user-defined ID or the DHCP client ID.
bootconfchk /etc/netboot/net-ip/client-ID/wanboot.conf
Check for WAN boot installation support in the client OBP.
eeprom | grep network-boot-arguments
Table 16–2 Preparing the WAN Boot Security Files
Command
Create a master HMAC SHA1 key for the WAN boot server.
wanbootutil keygen -m
Create a HMAC SHA1 hashing key for the client.
wanbootutil keygen -c -o net=net-ip,cid=client-ID,type=sha1
Create an encryption key for the client.
  • key-type is either 3des or aes.
wanbootutil keygen -c -o net=net-ip,cid=client-ID,type=key-type
Split a PKCS#12 certificate file and insert the certificate in the client's truststore.
  • p12cert is the name of the PKCS#12 certificate file.
wanbootutil p12split -i p12cert -t /etc/netboot/net-ip/client-ID/truststore
Split a PKCS#12 certificate file and insert the client certificate in the client's certstore
  • keyfile is the name of the client's private key.
wanbootutil p12split -i p12cert -c /etc/netboot/net-ip/client-ID/certstore -k keyfile
Insert the client private key from a split PKCS#12 file in the client's keystore.
  • client-ID can be a user-defined ID or a DHCP client ID.
wanbootutil keymgmt -i -k keyfile -s /etc/netboot/net-ip/client-ID/keystore -o type=rsa
Display the value of a HMAC SHA1 hashing key.
wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=sha1
Display the value of an encryption key.
wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=key-type
Insert a hashing key or an encryption key on a running system. key-type can have a value of sha1, 3des, or aes.
/usr/lib/inet/wanboot/ickey -o type=key-type
OBP Commands
The following table lists the OBP commands that you type at the client ok prompt to perform a WAN boot installation.
Table 16–3 OBP Commands for a WAN Boot Installation
OBP Command
Begin an unattended WAN boot installation.
boot net – install
Begin an interactive WAN boot installation.
boot net –o prompt - install
Begin a WAN boot installation from a local CD.
boot cdrom –F wanboot - install
Install a hashing key before you begin a WAN boot installation.key-value is the hexadecimal value of the hashing key.
set-security-key wanboot-hmac-sha1 key-value
Install an encryption key before you begin a WAN boot installation.
  • key-type is either wanboot-3des or wanboot-aes.
  • key-value is the hexadecimal value of the encryption key.
set-security-key key-type key-value
Verify that key values are set in OBP.
list-security-keys
Set client configuration variables before you begin your WAN boot installation.
  • client-IP is the IP address of the client.
  • router-ip is the IP address of the network router.
  • mask-value is the subnet mask value.
  • client-name is the host name of the client.
  • proxy-ip is the IP address of the network's proxy server.
  • wanbootCGI-path is the path to the wanbootCGI programs on the web server.
setenv network-boot-arguments host-ip=client-IP,router-ip=router-ip,subnet-mask=mask-value,hostname=client-name,http-proxy=proxy-ip,file=wanbootCGI-path
Check the network device alias.
devalias
Set the network device alias, where device-path is the path to the primary network device.
  • To set the alias for the current installation only, type devalias net device-path.
  • To permanently set the alias, type nvvalias net device-path.
System Configuration File Settings and Syntax
The system configuration file enables you to direct the WAN boot installation programs to the following files.
The system configuration file is a plain text file, and must be formatted in the following pattern.
setting=value
The system.conf file must contain the following settings.
SsysidCF=sysidcfg-file-URL
This setting points to the directory on the install server that contains the sysidcfg file. For WAN installations that use HTTPS, set the value to a valid HTTPS URL.
SjumpsCF=jumpstart-files-URL
This setting points to the custom JumpStart directory that contains the rules.ok and profile files. For WAN installations that use HTTPS, set the value to a valid HTTPS URL.
You can store the system.conf in any directory that is accessible to the WAN boot server.
wanboot.conf File Parameters and Syntax
The wanboot.conf file is a plain-text configuration file that the WAN boot installation programs use to perform a WAN installation. The following programs and files use the information included in the wanboot.conf file to install the client machine.
Save the wanboot.conf file in the appropriate client subdirectory in the /etc/netboot hierarchy on the WAN boot server. For information on how to define the scope of your WAN boot installation with the /etc/netboot hierarchy, see Creating the /etc/netboot Hierarchy on the WAN Boot Server.
You specify information in the wanboot.conf file by listing parameters with associated values in the following format.
parameter=value
Parameter entries cannot span lines. You can include comments in the file by preceding the comments with the # character.
For detailed information about the wanboot.conf file, see the man page wanboot.conf(4).
You must set the following parameters in the wanboot.conf file.
boot_file=wanboot-path
This parameter specifies the path to the wanboot program. The value is a path relative to the document root directory on the WAN boot server.
boot_file=/wanboot/wanboot.s10_sparc
root_server=wanbootCGI-URL/wanboot-cgi
This parameter specifies the URL of the wanboot-cgi program on the WAN boot server.
  • Use an HTTP URL if you are performing a WAN boot installation without client or server authentication.
    root_server=http://www.example.com/cgi-bin/wanboot-cgi
  • Use an HTTPS URL if you are performing a WAN boot installation with server authentication, or server and client authentication.
    root_server=https://www.example.com/cgi-bin/wanboot-cgi
root_file=miniroot-path
This parameter specifies the path to the WAN boot miniroot on the WAN boot server. The value is a path relative to the document root directory on the WAN boot server.
root_file=/miniroot/miniroot.s10_sparc
signature_type=sha1 | empty
This parameter specifies the type of hashing key to use to check the integrity of the data and files that are transmitted.
  • For WAN boot installations that use a hashing key to protect the wanboot program, set this value to sha1.
    signature_type=sha1
  • For insecure WAN installations that do not use a hashing key, leave this value blank.
    signature_type=
encryption_type=3des | aes | empty
This parameter specifies the type of encryption to use to encrypt the wanboot program and WAN boot file system.
  • For WAN boot installations that use HTTPS, set this value to 3des or aes to match the key formats you use. You must also set the signature_type keyword value to sha1.
    or
    encryption_type=aes
  • For an insecure WAN boot installations that do not use encryption key, leave this value blank.
    encryption_type=
server_authentication=yes | no
This parameter specifies if the server should be authenticated during the WAN boot installation.
  • For WAN boot installations with server authentication or server and client authentication, set this value to yes. You must also set the value of signature_type to sha1, encryption_type to 3des or aes, and the URL of root_server to an HTTPS value.
  • For insecure WAN boot installations that do not use server authentication or server and client authentication, set this value to no. You can also leave the value blank.
    server_authentication=no
client_authentication=yes | no
This parameter specifies if the client should be authenticated during a WAN boot installation.
  • For WAN boot installations with server and client authentication, set this value to yes. You must also set the value of signature_type to sha1, encryption_type to 3des or aes, and the URL of root_server to an HTTPS value.
  • For WAN boot installations that do not use client authentication, set this value to no. You can also leave the value blank.
    client_authentication=no
resolve_hosts=hostname | empty
This parameter specifies additional hosts that need to be resolved for the wanboot-cgi program during the installation.
Set the value to the host names of systems that are not specified previously in the wanboot.conf file or in a client certificate.
  • If all the required hosts are listed in the wanboot.conf file or the client certificate, leave this value blank.
    resolve_hosts=
  • If specific hosts are not listed in the wanboot.conf file or the client certificate, set the value to these host names.
    resolve_hosts=seahag,matters
boot_logger=bootlog-cgi-path | empty
This parameter specifies the URL to the bootlog-cgi script on the logging server.
  • To record boot or installation log messages on a dedicated logging server, set the value to the URL of the bootlog-cgi script on the logging server.
    boot_logger=http://www.example.com/cgi-bin/bootlog-cgi
  • To display boot and installation messages on the client console, leave this value blank.
    boot_logger=
system_conf=system.conf | custom-system-conf
This parameter specifies the path to the system configuration file that includes the location of sysidcfg and custom JumpStart files.
Set the value to the path to the sysidcfg and custom JumpStart files on the web server.
system_conf=sys.conf
