Begin an unattended WAN boot installation.
boot net – install
Begin an interactive WAN boot installation.
boot net –o prompt - install
Begin a WAN boot installation from a local CD.
boot cdrom –F wanboot - install
Install a hashing key before you
begin a WAN boot installation.key-value is the
hexadecimal value of the hashing key.
set-security-key wanboot-hmac-sha1 key-value
Install an encryption key before
you begin a WAN boot installation.
set-security-key key-type key-value
Verify that key values are set in
OBP.
list-security-keys
Set
client configuration variables before you begin your WAN boot installation.
client-IP is the IP address of
the client.
router-ip is the IP address of
the network router.
mask-value is the subnet mask value.
client-name is the host name of
the client.
proxy-ip is the IP address of the
network's proxy server.
wanbootCGI-path is the path to
the wanbootCGI programs on the web server.
setenv network-boot-arguments host-ip=client-IP,router-ip=router-ip,subnet-mask=mask-value,hostname=client-name,http-proxy=proxy-ip,file=wanbootCGI-path
Check the network device alias.
devalias
Set the network device
alias, where device-path is the path to the primary
network device.
To set the alias for the current installation only, type devalias net device-path.
To permanently set the alias, type nvvalias net device-path.
