Solaris 10 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Chapter 12 Solaris Live Upgrade (Examples)
This chapter provides examples of creating a boot environment, then upgrading and activating the new boot environment which then becomes the currently running system. This chapter contains the following sections:
Example of Upgrading With Solaris Live Upgrade (Command-Line Interface)
In this example, a new boot environment is created by using the lucreate command on a system that is running the Solaris 9 release. The new boot environment is upgraded to the Solaris 10 release by using the luupgrade command. The upgraded boot environment is activated by using the luactivate command. An example of falling back to the original boot environment is also given.
To Install Required Patches
Description
For More Information
Caution – Caution –
Correct operation of Solaris Live Upgrade requires that a limited set of patch revisions be installed for a particular OS version. Before installing or running Solaris Live Upgrade, you are required to install these patches.
x86 only –
Starting with the Solaris 1/06 release, if this set of patches is not installed, Solaris Live Upgrade fails and you might see the following error message. If you don't see the following error message, necessary patches still might not be installed. Always verify that all patches listed on the SunSolve info doc have been installed before attempting to install Solaris Live Upgrade.
ERROR: Cannot find or is not
executable: </sbin/biosdev>.
ERROR: One or more patches required by
Live Upgrade has not been installed.
The patches listed in info doc 72099 are subject to change at any time. These patches potentially fix defects in Solaris Live Upgrade, as well as fix defects in components that Solaris Live Upgrade depends on. If you experience any difficulties with Solaris Live Upgrade, please check and make sure that you have the latest Solaris Live Upgrade patches installed.
Ensure that you have the most recently updated patch list by consulting http://sunsolve.sun.com. Search for the info doc 72099 on the SunSolve web site.
If you are running the Solaris 8 or Solaris 9 OS, you might not be able to run the Solaris Live Upgrade installer. These releases do not contain the set of patches needed to run the Java 2 runtime environment. You must have the recommended patch cluster for the Java 2 runtime environment that is recommended to run the Solaris Live Upgrade installer and install the packages.
To install the Solaris Live Upgrade packages, use the pkgadd command. Or install, for the Java 2 runtime environment, the recommended patch cluster. The patch cluster is available at http://sunsolve.sun.com.
Follow these steps to install the required patches.
From the SunSolve web site, obtain the list of patches.
# patchadd /net/server/export/patches
# init 6
To Install Solaris Live Upgrade on the Active Boot Environment
  1. Insert the Solaris Operating System DVD or Solaris Software - 2 CD.
  2. Follow the step for the media you are using.
    • If you are using the Solaris Operating System DVD, change the directory to the installer and run the installer.
      # cd /cdrom/cdrom0/Solaris_10/Tools/Installers
      # ./liveupgrade20
      The Solaris installation program GUI is displayed.
    • If you are using the Solaris Software - 2 CD, run the installer.
      % ./installer
  3. From the Select Type of Install panel, click Custom.
  4. On the Locale Selection panel, click the language to be installed.
  5. Choose the software to install.
    • For DVD, on the Component Selection panel, click Next to install the packages.
    • For CD, on the Product Selection panel, click Default Install for Solaris Live Upgrade and click the other product choices to deselect this software.
  6. Follow the directions on the Solaris installation program panels to install the software.
To Create a Boot Environment
The source boot environment is named c0t4d0s0 by using the -c option. Naming the source boot environment is required only when the first boot environment is created. For more information about naming using the -c option, see the description in “To Create a Boot Environment for the First Time” Step 2.
The new boot environment is named c0t15d0s0. The -A option creates a description that is associated with the boot environment name.
The root (/) file system is copied to the new boot environment. Also, a new swap slice is created rather than sharing the source boot environment's swap slice.
# lucreate -A 'BE_description' -c c0t4d0s0 -m /:/dev/dsk/c0t15d0s0:ufs\
-m -:/dev/dsk/c0t15d0s1:swap -n c0t15d0s0
To Upgrade the Inactive Boot Environment
The inactive boot environment is named c0t15d0s0. The operating system image to be used for the upgrade is taken from the network.
# luupgrade -n c0t15d0s0 -u -s /net/ins-svr/export/Solaris_10 \
combined.solaris_wos
To Check if Boot Environment Is Bootable
The lustatus command reports if the boot environment creation is complete. lustatus also shows if the boot environment is bootable.
# lustatus
boot environment   Is        Active  Active     Can	    Copy
Name               Complete  Now	 OnReboot   Delete	 Status
c0t4d0s0           yes       yes      yes      no      -
c0t15d0s0          yes       no       no       yes     -
To Activate the Inactive Boot Environment
The c0t15d0s0 boot environment is made bootable with the luactivate command. The system is then rebooted and c0t15d0s0 becomes the active boot environment. The c0t4d0s0 boot environment is now inactive.
# luactivate c0t15d0s0
# init 6
(Optional) To Fall Back to the Source Boot Environment
The following procedures for falling back depend on your new boot environment activation situation:
Example 12–1 SPARC: To Fall Back Despite Successful Boot Environment Creation
In this example, the original c0t4d0s0 boot environment is reinstated as the active boot environment although it was activated successfully. The device name is first_disk.
# /sbin/luactivate first_disk
# init 6
Example 12–2 SPARC: To Fall Back From a Failed Boot Environment Activation
In this example, the new boot environment was not bootable. You must return to the OK prompt before booting from the original boot environment, c0t4d0s0, in single-user mode.
OK boot net -s
Do you want to fallback to activate boot environment c0t4d0s0
(yes or no)? yes
# init 6
The original boot environment, c0t4d0s0, becomes the active boot environment.
Example 12–3 SPARC: To Fall Back to the Original Boot Environment by Using a DVD, CD, or Net Installation Image
In this example, the new boot environment was not bootable. You cannot boot from the original boot environment and must use media or a net installation image. The device is /dev/dsk/c0t4d0s0. The original boot environment, c0t4d0s0, becomes the active boot environment.
OK boot net -s
# fsck /dev/dsk/c0t4d0s0
# mount /dev/dsk/c0t4d0s0 /mnt
# /mnt/sbin/luactivate
(yes or no)? yes
# umount /mnt
# init 6
Example 12–4 x86: To Fall Back to the Original Boot Environment By Using the GRUB Menu
Starting with the Solaris 10 1/06 release, the following example provides the steps to fall back by using the GRUB menu.
In this example, the GRUB menu is displayed correctly, but the new boot environment is not bootable. To enable a fallback, the original boot environment is booted in single-user mode.
  1. To display the GRUB menu, reboot the system.
    # init 6
    The GRUB menu is displayed.
    GNU GRUB version 0.95 (616K lower / 4127168K upper memory)
    |Solaris                                                            |
    |Solaris failsafe                                                   |
    |second_disk                                                        |
    |second_disk failsafe                                               |
    Use the ^ and v keys to select which entry is highlighted. Press
    enter to boot the selected OS, 'e' to edit the commands before
    booting, or 'c' for a command-line.
  2. From the GRUB menu, select the original boot environment. The boot environment must have been created with GRUB software. A boot environment that was created before the Solaris 10 1/06 release is not a GRUB boot environment. If you do not have a bootable GRUB boot environment, then skip to Example 12–5.
  3. Edit the GRUB menu by typing: e.
  4. Select kernel /boot/multiboot by using the arrow keys and type e. The grub edit menu is displayed.
    grub edit>kernel /boot/multiboot
  5. Boot to single user mode, by typing -s.
    grub edit>kernel /boot/multiboot -s
  6. Boot and mount the boot environment. Then activate it.
# b
(yes or no)? yes
# umount /mnt
# init 6
Example 12–5 x86: To Fall Back to the Original Boot Environment With the GRUB Menu by Using the DVD or CD
Starting with the Solaris 10 1/06 release, the following example provides the steps to fall back by using the DVD or CD.
In this example, the new boot environment was not bootable. Also, the GRUB menu does not display. To enable a fallback, the original boot environment is booted in single-user mode.
  1. Insert the Solaris Operating System for x86 Platforms DVD or Solaris Software for x86 Platforms - 1 CD.
  2. Boot from the DVD or CD.
    # init 6
    |Solaris                                                            |
    |Solaris failsafe                                                   |
  6. Boot and mount the boot environment. Then activate and reboot.
Select the original boot environment by using the arrow keys.
# b
(yes or no)? yes
# umount /mnt
# init 6
Example of Detaching and Upgrading One Side of a RAID-1 Volume (Mirror) (Command-Line Interface)
This example shows you how to do the following tasks:
Figure 12–1 shows the current boot environment, which contains three physical disks.
Figure 12–1 Detaching and Upgrading One Side of a RAID-1 Volume (Mirror)
The context describes the illustration.
  1. Create a new boot environment, second_disk, that contains a mirror.
    The following command performs these tasks.
    • lucreate configures a UFS file system for the mount point root (/). A mirror, d10, is created. This mirror is the receptacle for the current boot environment's root (/) file system, which is copied to the mirror d10. All data on the mirror d10 is overwritten.
    • Two slices, c0t1d0s0 and c0t2d0s0, are specified to be used as submirrors. These two submirrors are attached to mirror d10.
    # lucreate -c first_disk -n second_disk \
    -m /:/dev/md/dsk/d10:ufs,mirror \
    -m /:/dev/dsk/c0t1d0s0:attach \
    -m /:/dev/dsk/c0t2d0s0:attach
  2. Activate the second_disk boot environment.
    # /sbin/luactivate second_disk
    # init 6
  3. Create another boot environment, third_disk.
    • lucreate configures a UFS file system for the mount point root (/). A mirror, d20, is created.
    • Slice c0t1d0s0 is removed from its current mirror and is added to mirror d20. The contents of the submirror, the root (/) file system, are preserved and no copy occurs.
    # lucreate -n third_disk \
    -m /:/dev/md/dsk/d20:ufs,mirror \
    -m /:/dev/dsk/c0t1d0s0:detach,attach,preserve
  4. Upgrade the new boot environment, third_disk
    # luupgrade -u -n third_disk \
    -s /net/installmachine/export/Solaris_10/OS_image
  5. Add a patch to the upgraded boot environment.
    # luupgrade -t n third_disk -s /net/patches 222222-01
  6. Activate the third_disk boot environment to make this boot environment the currently running system.
    # /sbin/luactivate third_disk
    # init 6
  7. Delete the boot environment second_disk.
    # ludelete second_disk
  8. The following commands perform these tasks.
    • Clear mirror d10.
    • Check for the number for the concatenation of c0t2d0s0.
    • Attach the concatenation that is found by the metastat command to the mirror d20. The metattach command synchronizes the newly attached concatenation with the concatenation in mirror d20. All data on the concatenation is overwritten.
    # metaclear d10
    # metastat -p | grep c0t2d0s0
    dnum 1 1 c0t2d0s0
    # metattach d20 dnum
    num
    Is the number found in the metastat command for the concatenation
The new boot environment, third_disk, has been upgraded and is the currently running system. third_disk contains the root (/) file system that is mirrored.
Figure 12–2 shows the entire process of detaching a mirror and upgrading the mirror by using the commands in the preceding example.
Figure 12–2 Detaching and Upgrading One Side of a RAID-1 Volume (Mirror) (continued)
Example of Migrating From an Existing Volume to a Solaris Volume Manager RAID-1 Volume (Command-Line Interface)
Solaris Live Upgrade enables the creation of a new boot environment on RAID–1 volumes (mirrors). The current boot environment's file systems can be on any of the following:
However, the new boot environment's target must be a Solaris Volume Manager RAID-1 volume. For example, the slice that is designated for a copy of the root (/) file system must be /dev/vx/dsk/rootvol. rootvol is the volume that contains the root (/) file system.
In this example, the current boot environment contains the root (/) file system on a volume that is not a Solaris Volume Manager volume. The new boot environment is created with the root (/) file system on the Solaris Volume Manager RAID-1 volume c0t2d0s0. The lucreate command migrates the current volume to the Solaris Volume Manager volume. The name of the new boot environment is svm_be. The lustatus command reports if the new boot environment is ready to be activated and be rebooted. The new boot environment is activated to become the current boot environment.
# lucreate -n svm_be -m /:/dev/md/dsk/d1:mirror,ufs \
# lustatus
# luactivate svm_be
# lustatus
# init 6
Example of Creating an Empty Boot Environment and Installing a Solaris Flash Archive (Command-Line Interface)
The following procedures cover the three-step process:
The lucreate command creates a boot environment that is based on the file systems in the active boot environment. When you use the lucreate command with the -s - option, lucreate quickly creates an empty boot environment. The slices are reserved for the file systems specified, but no file systems are copied. The boot environment is named, but not actually created until installed with a Solaris Flash archive. When the empty boot environment is installed with an archive, file systems are installed on the reserved slices. The boot environment is then activated.
To Create an Empty Boot Environment
In this first step, an empty boot environment is created. Slices are reserved for the file systems that are specified, but no copy of file systems from the current boot environment occurs. The new boot environment is named second_disk.
# lucreate  -s - -m /:/dev/dsk/c0t1d0s0:ufs \
-n second_disk
The boot environment is ready to be populated with a Solaris Flash archive.
Figure 12–3 shows the creation of an empty boot environment.
Figure 12–3 Creating an Empty Boot Environment
To Install a Solaris Flash Archive on the New Boot Environment
In this second step, an archive is installed on the second_disk boot environment that was created in the previous example. The archive is located on the local system. The operating system versions for the -s and -a options are both Solaris 10 releases. The archive is named Solaris_10.flar.
# luupgrade -f -n second_disk \
-s /net/installmachine/export/Solaris_10/OS_image \
-a /net/server/archive/Solaris_10.flar
The boot environment is ready to be activated.
To Activate the New Boot Environment
In this last step, the second_disk boot environment is made bootable with the luactivate command. The system is then rebooted and second_disk becomes the active boot environment.
# luactivate second_disk
# init 6
Example of Upgrading Using Solaris Live Upgrade (Character Interface)
In this example, a new boot environment is created on a system that is running the Solaris 9 release. The new boot environment is upgraded to the Solaris 10 release. The upgraded boot environment is then activated.
  2. Run the installer for the media you are using.
    • If you are using the Solaris Operating System DVD, change directories to the installer and run the installer.
      # ./liveupgrade20
      % ./installer
    • For CD, on the Product Selection panel, click Default Install for Solaris Live Upgrade and click the other product choices to deselect the software.
Description
Caution – Caution –
x86 only –
Starting with the Solaris 10 1/06 release, if this set of patches is not installed, Solaris Live Upgrade fails and you might see the following error message. If you don't see the following error message, necessary patches still might not be installed. Always verify that all patches listed on the SunSolve info doc have been installed before attempting to install Solaris Live Upgrade.
ERROR: Cannot find or is not executable:
</sbin/biosdev>.
Ensure you have the most recently updated patch list by consulting http://sunsolve.sun.com. Search for the info doc 72099 at the SunSolve web site.
To install the Solaris Live Upgrade packages, use the pkgadd command. Or install, for the Java 2 runtime environment, the recommended patch cluster. The patch cluster is available on http://sunsolve.sun.com.
# init 6
In this example, the source boot environment is named c0t4d0s0. The root (/) file system is copied to the new boot environment. Also, a new swap slice is created instead of sharing the source boot environment's swap slice.
  1. Display the character user interface:
    # /usr/sbin/lu
    The Solaris Live Upgrade Main Menu is displayed.
  2. From the main menu, select Create.
    Name of Current Boot Environment:    c0t4d0s0
    Name of New Boot Environment:   c0t15d0s0
  3. Press F3.
    The Configuration menu is displayed.
  4. To select a slice from the configuration menu, press F2.
    The Choices menu is displayed.
  5. Choose slice 0 from disk c0t15d0 for the root (/) file system.
  6. From the configuration menu, create a new slice for swap on c0t15d0 by selecting a swap slice to be split.
  7. To select a slice for swap, press F2. The Choices menu is displayed.
  8. Select slice 1 from disk c0t15d0 for the new swap slice.
  9. Press F3 to create the new boot environment.
The new boot environment is then upgraded. The new version of the operating system for the upgrade is taken from a network image.
  1. From the main menu, select Upgrade.
    Package Media: /net/ins3-svr/export/Solaris_10/combined.solaris_wos
  2. Press F3.
The c0t15d0s0 boot environment is made bootable. The system is then rebooted and c0t15d0s0 becomes the active boot environment. The c0t4d0s0 boot environment is now inactive.
  1. From the main menu, select Activate.
    Name of Boot Environment: c0t15d0s0
    Do you want to force a Live Upgrade sync operations: no
  2. Press F3.
  3. Press Return.
  4. Type:
    # init 6
If a fallback is necessary, use the command-line procedures in the previous example: (Optional) To Fall Back to the Source Boot Environment.
