This procedure displays the description of the boot environment that is named in the command.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Type:
# /usr/sbin/ludesc -n BE_name |
Specifies the boot environment name.
In this example, the description is determined by using the -n option with the boot environment name.
# /usr/sbin/ludesc -n second_disk Solaris 10 test build |
