Solaris Live Upgrade is included in the Solaris software. You need to install the Solaris Live Upgrade packages on your current OS. The release of the Solaris Live Upgrade packages must match the release of the OS you are upgrading to. For example, if your current OS is the Solaris 9 release and you want to upgrade to the Solaris 10 release, you need to install the Solaris Live Upgrade packages from the Solaris 10 release.
Table 7–1 lists releases that are supported by Solaris Live Upgrade.
Table 7–1 Supported Solaris Releases
Your Current Release |
Compatible Upgrade Release |
Solaris 8 OS |
Solaris 8, 9, or any Solaris 10 release |
Solaris 9 OS |
Solaris 9 or any Solaris 10 release |
Solaris 10 OS |
Any Solaris 10 release |
