Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations
Profile Examples
The following examples of profiles show how to use different profile keywords and profile values to control how the Solaris software is installed on a system. Profile Keywords and Values contains a description of profile keywords and values.
Example 6–2 Mounting Remote File Systems and Adding and Deleting Packages
# profile keywords        profile values
  install_type            initial_install
  system_type             standalone
  partitioning            default
  filesys                 any 512 swap   # specify size of /swap
  cluster                 SUNWCprog
  package                 SUNWman delete
  cluster                 SUNWCacc
The following list describes some of the keywords and values from this example.
install_type
The install_type keyword is required in every profile.
system_type
The system_type keyword defines that the system is to be installed as a standalone system.
partitioning
The file system slices are determined by the software to be installed with the value default. The size of swap is set to 512 Mbytes and is installed on any disk, value any.
cluster
The Developer Solaris Software Group, SUNWCprog, is installed on the system.
package
If the standard man pages are mounted from the file server, s_ref, on the network, the man page packages are not to be installed on the system. The packages that contain the System Accounting utilities are selected to be installed on the system.
Example 6–3 Mounting Remote File Systems and Adding a Third-Party Package
  cluster                 SUNWCprog
  cluster                 SUNWCacc
  package                 apache_server  \
                           http://package.central/packages/apache timeout 5
install_type
system_type
partitioning
cluster
package
A third-party package is installed on the system located on an HTTP server.
Example 6–4 Specifying Where to Install File Systems
  partitioning            explicit
  filesys                 c0t0d0s0 auto /
  filesys                 c0t3d0s1 auto swap
  filesys                 any auto usr
  cluster                 SUNWCall
partitioning
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the selected software, value auto, and is installed on c0t0d0s0. The size of swap is set to the necessary size and is installed on c0t3d0s1. usr is based on the selected software and the installation program determines where usr is installed, based on the value any.
cluster
The Entire Solaris Software Group, SUNWCall, is installed on the system.
Example 6–5 Upgrading and Installing Patches
  install_type             upgrade
  root_device              c0t3d0s2
  backup_media             remote_filesystem timber:/export/scratch
  package                  SUNWbcp delete
  package                  SUNWxwman add
  cluster                  SUNWCacc add
  patch                    patch_list nfs://patch_master/Solaris_10/patches\
                           retry 5
  locale                   de
install_type
The profile upgrades a system by reallocating disk space. In this example, disk space must be reallocated because some file systems on the system did not have enough space for the upgrade.
root_device
The root file system on c0t3d0s2 is upgraded.
backup_media
A remote system that is named timber is to be used to back up data during the disk space reallocation. For more backup-media keyword values, see backup_media Profile Keyword.
package
The binary compatibility package, SUNWbcp, is not installed on the system after the upgrade.
package
The code ensures that the X Window System man pages and the System Accounting Utilities are to be installed if they are not already installed on the system. All packages already on the system are automatically upgraded.
patch
A list of patches that are installed with the upgrade. The patch list is located on an NFS server named patch_master under the directories Solaris_10/patches. In case of a mount failure, the NFS mount is tried five times.
locale
The German localization packages are to be installed on the system.
Example 6–6 Reallocating Disk Space for an Upgrade
  layout_constraint        c0t3d0s2 changeable 100
  layout_constraint        c0t3d0s4 changeable
  layout_constraint        c0t3d0s5 movable
  locale                   de
install_type
root_device
backup_media
layout_constraint
The layout_constraint keywords designate that auto-layout can perform the following when auto-layout attempts to reallocate disk space for the upgrade.
  • Change slices 2 and 4. The slices can be moved to another location and the size can be changed.
  • Move slice 5. The slice can be moved to another location but its size cannot change.
package
package
locale
Example 6–7 Retrieving a Solaris Flash Archive From an HTTP Server
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from an HTTP server.
install_type               flash_install
archive_location           http://192.168.255.255/flasharchive/solarisarchive
filesys                    c0t1d0s0 4000 /
filesys                    c0t1d0s1 512 swap
filesys                    c0t1d0s7 free /export/home
install_type
The profile installs a Solaris Flash archive on the clone system. All files are overwritten as in an initial installation.
archive_location
The Solaris Flash archive is retrieved from an HTTP server.
partitioning
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the size of the Solaris Flash archive. The root file system is installed on c0t1d0s0. The size of swap is set to the necessary size and is installed on c0t1d0s1. /export/home is based on the remaining disk space. /export/home is installed on c0t1d0s7.
Example 6–8 Retrieving a Solaris Flash Archive From a Secure HTTP Server
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from a secure HTTP server.
archive_location           https://192.168.255.255/solarisupdate.flar
install_type
archive_location
The compressed Solaris Flash archive is retrieved from a secure HTTP server.
partitioning
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the size of the Solaris Flash archive. The size of swap is set to the necessary size and is installed on c0t1d0s1. /export/home is based on the remaining disk space. /export/home is installed on c0t1d0s7.
Example 6–9 Retrieving a Solaris Flash Archive and Installing a Third-Party Package
package                    SUNWnew http://192.168.254.255/Solaris_10 timeout 5
install_type
archive_location
partitioning
package
The SUNWnew package is added from the Solaris_10 directory from the HTTP server 192.168.254.255.
Example 6–10 Retrieving a Solaris Flash Differential Archive From an NFS Server
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from an NFS server. The flash_update keyword indicates that this is a differential archive. A differential archive installs only the differences between two system images.
install_type               flash_update
archive_location           nfs installserver:/export/solaris/flasharchive \
                           /solarisdiffarchive
no_master_check
install_type
The profile installs a Solaris Flash differential archive on the clone system. Only files that are specified by the archive are installed.
archive_location
The Solaris Flash archive is retrieved from an NFS server.
no_master_check
The clone system is not checked for a valid system image. A valid system image would have been built from the original master system.
Example 6–11 Creating an Empty Boot Environment
In the following example, the profile indicates that the custom JumpStart program creates an empty boot environment. An empty boot environment contains no file systems and no copy from the current boot environment occurs. The boot environment can be populated later with a Solaris Flash archive and then activated.
  cluster                 SUNWCall
  bootenv createbe bename second_BE \
  filesystem /:/dev/dsk/c0t1d0s0:ufs \
  filesystem -:/dev/dsk/c0t1d0s0:swap \
  filesystem /export:shared:ufs
partitioning
cluster
bootenv createbe
An empty, inactive boot environment is set up on disk c0t1d0. File systems for root (/), swap, and /export are created, but left empty. This second boot environment can be installed with a Solaris Flash archive at a later time. The new boot environment can then be activated to become the current boot environment.
For keyword values and background about using this keyword, see the following references:
Example 6–12 Creating RAID-1 Volumes When Installing a Solaris Flash Archive
In the following example, the profile indicates that the custom JumpStart program uses Solaris Volume Manager technology to create RAID-1 volumes (mirrors) for the root (/), swap, /usr and /export/home file systems. A Solaris Flash archive is installed on the boot environment.
  arhcive_location        nfs server:/export/home/export/flash.s10.SUNWCall
  filesys                 mirror:d10 c0t0d0s0 c0t1d0s0 4096 /
  filesys                 mirror c0t0d0s1 2048 swap
  filesys                 mirror:d30 c0t0d0s3 c0t1d0s3 4096 /usr
  filesys                 mirror:d40 c0t0d0s4 c0t1d0s4 4096 /usr
  filesys                 mirror:d50 c0t0d0s5 c0t1d0s5 free /export/home
  metadb                  c0t1d0s7 size 8192 count 3
install_type
archive_location
partitioning
filesys
The root (/) file system is created and mirrored on the slices c0t0d0s0 and c0t1d0s0. The size of the root (/) file system is set to 4096 Mbytes. The RAID-1 volume that mirrors c0t0d0s0 and c0t1d0s0 is named d10.
filesys
The swap file system is created and mirrored on the slice c0t0d0s1, and is sized at 2048 Mbytes. The custom JumpStart program assigns a name to the mirror.
filesys
The /usr file system is created and mirrored on the slices c0t1d0s3 and c0t0d0s3. The size of the /usr file system is set to 4096 Mbytes. The RAID-1 volume is named d30.
filesys
The /usr file system is created and mirrored on the slices c0t1d0s4 and c0t0d0s4. The size of the /usr file system is set to 4096 Mbytes. The RAID-1 volume is named d40.
metadb
Three state database replicas (metadbs) are installed on slice c0t1d0s7, and are sized at 8192 blocks (4 Mbytes).
Example 6–13 Creating a RAID-1 Volume to Mirror the Root File System
In the following example, the profile indicates that the custom JumpStart program uses Solaris Volume Manager technology to create a RAID-1 volume (mirror) for the root (/) file system.
  cluster                 SUNWCXall
  filesys                 mirror:d30 c0t1d0s0 c0t0d0s0  /
  filesys                 c0t0d0s3 512 swap
  metadb                  c0t0d0s4 size 8192 count 4
  metadb                  c0t1d0s4 size 8192 count 4
cluster
The Entire Solaris Software Plus OEM Support software group, SUNWCXall, is installed on the system.
filesys
The root (/) file system is created and mirrored on the slices c0t1d0s0 and c0t0d0s0. The RAID-1 volume that mirrors c0t1d0s0 and c0t0d0s0 is named d30. The custom JumpStart program assigns names to the two submirrors.
filesys
The swap file system is created and mirrored on the slice c0t0d0s3, and is sized at 512 Mbytes.
metadb
Four state database replicas (metadbs) are installed on slice c0t0d0s4, and are sized at 8192 blocks (4 Mbytes).
metadb
Four state database replicas (metadbs) are installed on slice c0t1d0s4, and are sized at 8192 blocks (4 Mbytes).
Example 6–14 Creating RAID-1 Volumes to Mirror Multiple File Systems
In the following example, the profile indicates that the custom JumpStart program uses Solaris Volume Manager technology to create RAID-1 volumes (mirrors) for the root (/), swap, and /usr file systems.
  cluster                 SUNWCXall
  filesys                 mirror:d100 c0t1d0s0 c0t0d0s0 200 /
  filesys                 c0t1d0s5 500 /var
  filesys                 c0t0d0s5 500
  filesys                 mirror c0t0d0s1 512 swap
  metadb                  c0t0d0s3 size 8192 count 5
  filesys                 mirror c0t1d0s4 c0t0d0s4 2000 /usr
  filesys                 c0t0d0s7 free
cluster
filesys
The root (/) file system is created and mirrored on the slices c0t1d0s0 and c0t0d0s0. The size of the root (/) file system is set to 200 Mbytes. The RAID-1 volume that mirrors c0t1d0s0 and c0t0d0s0 is named d100.
filesys
The /var file system is installed on the slice c0t1d0s5 and is sized at 500 Mbytes. The root (/) file system is created and mirrored on the slices c0t1d0s0 and c0t0d0s0. The size of the root (/) file system is set to 200 Mbytes. The RAID-1 volume that mirrors c0t1d0s0 and c0t0d0s0 is named d100.
filesys
The swap file system is created and mirrored on the slice c0t0d0s1, and is sized at 512 Mbytes. The custom JumpStart program assigns a name to the mirror.
metadb
Five state database replicas (metadbs) are installed on slice c0t0d0s3, and are sized at 8192 blocks (4 Mbytes).
filesys
The /usr file system is created and mirrored on the slices c0t1d0s4 and c0t0d0s4. The size of the /usr file system is set to 2000 Mbytes. The custom JumpStart program assigns a name to the mirror.
Example 6–15 x86: Using the fdisk Keyword
  fdisk                 c0t0d0 0x04 delete
  fdisk                 c0t0d0 solaris maxfree
  cluster               SUNWCall
  cluster               SUNWCacc delete
fdisk
All fdisk partitions of type DOSOS16 (04 hexadecimal) are deleted from the c0t0d0 disk.
fdisk
A Solaris fdisk partition is created on the largest contiguous free space on the c0t0d0 disk.
cluster
The Entire Distribution software group, SUNWCall, is installed on the system.
cluster
The system accounting utilities, SUNWCacc, are not to be installed on the system.
