Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations
client_root Profile Keyword
client_root root_size
client_root defines the amount of root space, root_size in Mbytes, to allocate for each client. If you do not specify client_root in a server's profile, the installation software allocates 15 Mbytes of root space per client. The size of the client root area is used in combination with the num_clients keyword to determine how much space to reserve for the /export/root file system.
Note –
You can use client_root only when system_type is specified as server.
