Identify the system configuration that you want to install.
With the use of the Solaris installation programs, install the Solaris OS on the master system. For a discussion of the different installation program , refer to Choosing a Solaris Installation Method in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
Customize your Solaris installation in any of the following ways:
Delete software.
Add software.
Modify configuration files.
Add support for peripheral devices on the clone system.
You can create custom scripts or use the flar create command to create the archive.
To create custom scripts, see Creating Customization Scripts.
To create the archive, see Creating a Solaris Flash Archive.
