Solaris 10 Installation Guide: Solaris Flash Archives (Creation and Installation)
ProcedureTo Create a Solaris Flash Archive for an Initial Installation
After you install the master system, create a Solaris Flash archive to use to install other systems.
  1. Boot the master system and run it in as inactive a state as possible.
    When possible, run the system in single-user mode. If that is not possible, shut down any applications that you want to archive and any applications that require extensive operating system resources.
    You can create a Solaris Flash archive while the master system is running in multiuser mode, single-user mode, or while booted from one of the following:
    • Solaris Operating System DVD.
    • Solaris Software - 1 CD.
    • An image of the Solaris Software. If you are using CD media, the image could include the Solaris Languages CD if needed.
  2. To create the archive, use the flar create command.
    # flar create -n name options path/filename
    The name that you give the archive. The name you specify is the value of the content_name keyword.
    For a description of options, see flar create.
    The path to the directory in which you want to save the archive file. If you do not specify a path, flar create saves the archive file in the current directory.
    The name of the archive file.
    • If the archive creation is successful, the flar create command returns an exit code of 0.
    • If the archive creation fails, the flar create command returns a nonzero exit code.
  3. Make a copy of the archive and save it. The copy can be used in the future to update a clone system with a differential archive.
