Solaris 10 Installation Guide: Solaris Flash Archives (Creation and Installation)
Administering Solaris Flash Archives
The flar command enables you to administer archives. You can split an archive into sections. Those sections can be modified, added to, or deleted, and then merged to create an archive. You can also obtain information about the archive.
Caution – Caution –
Do not modify the Archive Files section or you compromise the integrity of the archive.
Splitting a Solaris Flash Archive
You can split an archive into sections, which enables you to modify some sections, add new sections, or delete sections. After you have modified the sections, you need to merge the sections to create an new archive. For example, you might want to add a User-Defined section or modify the Archive Identification section. Do not modify the Archive Files section or you compromise the integrity of the archive.
The flar split command splits a Solaris Flash archive into sections. The flar command copies each section into a separate file in the current directory or specified directory. The files are named after the sections, for example, the archive cookie is saved in a file that is named cookie. You can specify that the flar split command save only one section. The syntax of the command is as follows:
flar split[-d dir] [-u section] [-f archive] [-S section] [-t [-p posn] [-b blocksize]] filename
-d dir
Retrieves the sections to copy from dir, rather than from the current directory.
-u section
  • If you use this option, flar copies the Cookie, Identification, Archive, and section sections. You can specify a single section name or a space-separated list of section names.
  • If you do not use this option, flar copies the Cookie, Identification, and Archive sections only.
-f archive
Extracts the Archive section into a directory that is named archive, rather than placing it in a file with the name archive.
-S section
Only copies the section that is named section from the archive. This section is user defined.
Example 4–1 Splitting an Archive
In the following example, archive1.flar is split into three files:
# flar split archive1.flar
After the archive is split, you can modify the Archive Identification section or add a User-Defined section. The sections can then be merged to re-create the archive.
Merging a Solaris Flash Archive
After you have split an archive into sections, you can combine the sections to create a new archive.
The flar combine command creates a Solaris Flash archive from individual sections. Each section is assumed to be in a separate file, the names of which are the section names. At a minimum, these three files must be present:
When combining sections, remember the following points:
flar combine [-d dir] [-u section] [-t [-p posn] [-b blocksize]] filename
-d dir
Retrieves the sections to combine from dir, rather than from the current directory.
-u section
Example 4–2 Merging a Solaris Flash Archive
In this example, an Archive Cookie section, an Archive Identification section, and an Archive Files section are combined to become a complete archive. The archive is named newarchive.flar.
# flar combine newarchive.flar
Example 4–3 Merging a Solaris Flash Archive and Adding a User-Defined Section
In this example, an Archive Cookie section, an Archive Identification section, an Archive Files section, and a User-Defined section are combined to become a complete archive. The archive is named newarchive.flar. The User-Defined section content is in the file that is named user-defined, which is in the current directory.
# flar combine -u user_defined newarchive.flar
Extracting Information From an Archive
Use the flar info command to get information about archives you have already created. The syntax of the command is as follows:
flar info [-l] [-k keyword] [-t [-p posn] [-b blocksize]] filename
-k keyword
Returns only the value of the keyword keyword.
-l
Lists all the files in the archive section.
Example 4–4 Listing Files in an Archive Section
In this example, the command checks the file structure of the archive named archive3.flar.
# flar info -l archive3.flar
aaa
aaa/bbb
aaa/bbb/ccc
aaa/bbb/ccc/ddd
aaa/eee
