Solaris 10 Installation Guide: Solaris Flash Archives (Creation and Installation)
Chapter 5 Solaris Flash (Reference)
This chapter provides a description of Solaris Flash sections, keywords, and keyword values. Also, the chapter describes the flar create command options.
Solaris Flash Archive Section Descriptions
Each Solaris Flash archive is grouped into sections. Some sections are generated by the Solaris Flash software and need no input from you. Some sections require input or optionally allow you to add information. The following table describes each section.
Table 5–1 Flash Archive Sections
Section Name
Description
Required by Archive?
Requires Input From User?
Archive cookie
The first section contains a cookie that identifies the file as a Solaris Flash archive. The deployment code uses the cookie for identification and validation purposes. The cookie must be present for an archive to be valid.
Yes
No
Archive identification
The second section contains keywords with values that provide identification information about the archive. The software generates some information such as the following:
  • The archive ID number
  • The method of archival such as cpio
  • The creation date by default
You are required to specify a name for the Solaris Flash archive. Other information that you can specify about the archive includes the following:
  • The author of the archive
  • The date that the archive was created
  • The name of the master system that you used to create the archive
For a list of keywords that describe the archive, see Identification Section Keywords.
Yes
Content is generated by both user and the software
Manifest
A section of a Solaris Flash archive that is used to validate a clone system. The manifest section lists the files on a system to be retained, added to, or deleted from the clone system. The installation fails if the files do not match the expected file set. This section is informational only. The section lists the files in an internal format and cannot be used for scripting.
You can exclude this section by creating the differential archive with the flar create -M option. Because no validation of the archive occurs, excluding this section is not recommended.
No
No
Predeployment, Postdeployment, Reboot
This section contains internal information that the flash software uses before and after installing an OS image. Any customization scripts that you have provided are stored in this section.
Yes
No
Summary
This section contains messages about the archive creation and records the activities of predeployment scripts.
Yes
User-defined
This section follows the archive identification section. The archive can contain zero or more user-defined sections. These sections are not processed by the archive extraction code. These sections are retrieved separately and can be used for content descriptions.
No
Yes
Archive files
The archive files section contains the files that have been gathered from the master system in binary data. This section begins with section_begin=archive, but it does not have an ending section boundary.
Yes
No
Solaris Flash Keywords
Solaris Flash keywords are like custom JumpStart keywords. They define elements of the installation. Each keyword is a command that controls one aspect of how the Solaris Flash software installs the software on a clone system.
Use the following guidelines to format keywords and values:
General Keywords
Each Solaris Flash archive section is defined by the section_begin and section_end keywords. For example, the archive files section includes a section_begin keyword, though with a different value. User-defined archive sections are delimited by section_begin and section_end keywords, with values appropriate to each section. The values for the section_begin and section_end keywords are described in the following table.
Table 5–2 Values for section_begin and section_end Keywords
Archive Section
Value for section_begin and section_end keywords
Archive cookie
cookie – This section is not delimited by the section_begin and section_end keywords.
identification
User-defined sections
section_name – An example of a section_name keyword is X-user_section_1.
Archive files
archive
The following tables describe the keywords for use in the Archive Identification section and the values you can define for them.
Every section uses the keywords in Table 5–3 to delimit each section.
Table 5–3 Identification Section Keywords: General Keywords
Keywords
Value Definitions
Value
Required
section_begin
section_end
These keywords are used to delimit sections in the archive and are not limited exclusively to the identification section. For a description of these keywords, see General Keywords.
Text
Yes
The following keywords, used in the archive identification section, describe the contents of the archive files section.
Table 5–4 Identification Section Keywords: Contents of Archive Files Section
Keywords
Value Definitions
Value
Required
archive_id (optional)
This keyword uniquely describes the contents of the archive. This value is used by the installation software only to validate the contents of the archive during archive installation. If the keyword is not present, no integrity check is performed.
For example, the archive_id keyword might be FlAsH-ARcHive-2.0.
Text
No
files_archived_method
This keyword describes the archive method that is used in the files section.
  • If the keyword is present, it has the value of cpio.
  • If this keyword is not present, the files section is assumed to be in cpio format with ASCII headers. This format is the cpio -c option.
If the files_compressed_method is present, the compression method is applied to the archive file that is created by the archive method.
Text
No
files_archived_size
This keyword value is the size of the archived files section in bytes.
Numeric
No
files_compress_method
This keyword describes the compression algorithm that is used on the files section.
  • If the keyword is present, it can have one of the following values.
    • none – The archive file section is not compressed.
    • compress – The file section is compressed by using the compress command.
  • If this keyword is not present, the archive files section is assumed to be uncompressed.
The compression method that is indicated by this keyword is applied to the archive file created by the archive method indicated by the files_archived_method keyword.
Text
No
files_unarchived_size
This keyword defines the cumulative size in bytes of the extracted archive. The value is used for file-system size verification.
Numeric
No
The following keywords provide descriptive information about the entire archive. These keywords are generally used to assist you in archive selection and to aid in archive management. These keywords are all optional and are used to help you to distinguish between individual archives. You use options for the flar create command to include these keywords. For an example, see Example 3–8.
Table 5–5 Identification Section Keywords: User Describes the Archive
Keywords
Value Definitions
Value
Required
creation_date
This keyword value is a textual timestamp that represents the time that you created the archive.
  • You can use the flar create command with the -i option to create the date.
  • If you do not specify a creation date with the flar create command, the default date is set in Greenwich mean time (GMT).
  • The value must be in ISO-8601 complete basic calendar format without the time designator (ISO-8601,§5.4.1(a)). The format is CCYYMMDDhhmmss. For example, 20000131221409 represents January 31, 2000, 10:14:09 p.m.
Text
No
creation_master
This keyword value is the name of the master system you used to create the archive. You can use the flar create -m option to create this value. If you do not specify a value, the value is taken from the uname -n command.
Text
No
content_name
This keyword identifies the archive. The value is generated from the flar create -n option. Follow these guidelines when you create this value:
  • The descriptive name can be no longer than 256 characters.
  • The description should contain the function and purpose of the archive.
Text
Yes
content_type
This keyword value specifies a category for the archive. You use the flar create -T option to generate the value.
Text
No
content_description
The keyword value describes the contents of the archive. The value of this keyword has no length limit. You use the flar create -E option to create this value.
Text
No
content_author
This keyword value identifies the creator of the archive. You use the flar create-a option to create this value. Suggested values include the full name of the creator and the creator's email address.
Text
No
content_architectures
This keyword value is a comma-separated list of the kernel architectures that the archive supports.
  • If the keyword is present, the installation software validates the kernel architecture of the clone system against the list of architectures that the archive supports. The installation fails if the archive does not support the kernel architecture of the clone system.
  • If the keyword is not present, the installation software does not validate the architecture of the clone system.
Text list
No
The following keywords also describe the entire archive. By default, the values are filled in by uname when the flash archive is created. If you create a flash archive in which the root directory is not /, the archive software inserts the string UNKNOWN for the keywords. The exceptions are the creation_node, creation_release, and creation_os_name keywords.
Regardless of their sources, you cannot override the values of these keywords.
Table 5–6 Identification Section Keywords: Software Describes the Archive
Keyword
Value
creation_node
The return from uname -n
creation_hardware_class
The return from uname -m
creation_platform
The return from uname -i
creation_processor
The return from uname -p
creation_release
The return fromuname -r
creation_os_name
The return from uname -s
creation_os_version
The return from uname -v
User-Defined Section Keywords
In addition to the keywords that are defined by the Solaris Flash archive, you can define other keywords. The Solaris Flash archive ignores user-defined keywords, but you can provide scripts or programs that process the identification section and use user-defined keywords. Use the following format when creating user-defined keywords:
For example, X-department is a valid name for a user-defined keyword.
For an example of using options to include user-defined keywords in the identification section, see Example 3–8.
Solaris Flash flar create Command
Use the Solaris Flash flar create command to create a Solaris Flash archive.
flar create
Use the flar create command to create a Solaris Flash archive from a master system. You can use this command when the master system is running in multiuser mode or single-user mode. You can also use flar create when the master system is booted from the following media.
The master system should be in as stable a state as possible when you create a Solaris Flash archive. The syntax of the command is as follows:
flar create -n archive_name [-R root] [-A unchanged_master_image_dir] [-S] [-M] [-H] [-I] [-c] [-x exclude_dir/filename] [-y include_dir/filename] [-z list_filename] [-X list_filename] [-t [-p posn] [-b blocksize] [-i date] [-m master] [-u section ... [-d dir]] [-f [list_filename| -] [-F]] [-U key=val ...] [-a author] [-e descr|-E descr_file] [-T type] path/filename
In this command line, path is the directory in which you want the archive file to be saved. filename is the name of the archive file. If you do not specify a path, flar create saves the archive file in the current directory.
Table 5–7 Command-Line Options for flar create
Option
Description
Required Options
-n archive_name
The value of this flag is the name of the archive. The archive_name you specify is the value of the content_name keyword.
Option for Compression
-c
Compresses the archive by using compress(1).
Options for Directories and Sizes
-R root
Creates the archive from the file system tree that is rooted at root. If you do not specify this option, flar create creates an archive from a file system that is rooted at /.
-S
Omits sizing information in the archive.
-H
Does not generate the hash identifier.
Options for Creating a Differential Archive
Creates a differential archive by comparing a new system image with the image that is specified by the unchanged_master_image_dir argument. By default, the new system image is root (/). You can change the default with the -R option. unchanged_master_image_dir is a directory where the unchanged master system image is stored or mounted through UFS, NFS, or lumount.
You can modify the effects of file selection for a differential archive by using the options for contents selection described in the next section of the table.
-M
Excludes the manifest file. When you use this option, no validation occurs on the differential archive. When creating a differential archive, flar create creates a long list of the files in the system that are unchanged, are changed, and are to be deleted from the archive. This list is stored in the manifest section of the archive. When the differential archive is deployed, the software uses this list to perform a file-by-file check, ensuring the integrity of the clone system. Use of this option avoids such a check and saves the space that is used by the manifest section in a differential archive. However, you must consider the savings in time and disk space against the loss of an integrity check upon installation. Because no validation occurs, avoid using this option.
Options for Contents Selection
Caution – Caution –
Use the flar create file-exclusion options with caution. If you exclude some directories, others that you were unaware of might be left in the archive, such as system configuration files. The system would then be inconsistent and the installation would not work. Excluding directories and files is best used with data that can easily be removed without disrupting the system, such as large data files.
Adds to the archive those files and directories that are specified on the command line. This option is used when you have excluded a directory, but want to restore individual subdirectories or files.
include_dir/filename is the name of the subdirectory or file to be included.
-f list_filename
Adds files and directories from a list to the archive.
list_filename is the full path to a file that contains a list. The contents of the file are added to the file list unless -F is specified.
  • The list_filename file must contain one file per line.
  • If you specify a file system with -R root, the path to each file must be relative to the alternate root directory or an absolute path.
  • If filename is “-”, flar create reads standard input as the list of files. When you use the value “-”, the archive size is not calculated.
-F
Uses only the files in -f list_filename to create the archive. This option makes the -f list_filename the absolute list, rather than a list that is appended to the normal file list.
Excludes files and directories from the archive. These files and directories are specified at the command line. You can use multiple instances of this option to exclude more than one file or directory.
exclude_dir/filename is the name of the directory or file to be excluded.
-X list_filename
Excludes a list of files or directories from the archive.
list_filename is the full path to a file that contains the list.
  • If list_filename is “-”, flar create reads standard input as the list of files. When you use the value “-”, the archive size is not calculated.
-z list_filename
Excludes or includes a list of files or directories from the archive. Each file or directory in the list is noted with a plus “+” or minus “-”. A plus indicates an included file or directory and the minus indicates an excluded file or directory.
-I
Override the integrity check. To prevent you from excluding important system files from an archive, flar create runs an integrity check. This check examines all files that are registered in a system package database and stops archive creation if any of them are excluded. Use of this option overrides this integrity check. Therefore, avoid the use of the -I option.
Options Used With User-Defined Sections
-u section
Includes section as a user-defined section. To include more than one user-defined section, section must be a space-separated list of section names.
-d dir
Retrieves the section file that is specified with -u from dir.
Options Used With Tape Archives
-t
Creates an archive on a tape device. The filename argument is the name of the tape device.
-p posn
Use only with the -t option. Specifies the position on the tape device for flar create to store the archive. If you do not use this option, flar create places the archive at the current position of the tape.
-b blocksize
Specifies the block size flar create uses when creating the archive. If you do not specify a block size, flar create uses the default block size of 64 KB.
Options for Archive Identification
These keywords and values appear in the identification section of the archive.
-U key=val
Includes user-defined keywords and values in the Archive Identification section.
-i date
Uses date as the value for the creation_date keyword. If you do not specify a date, flar create uses the current system time and date.
-m master
Uses master as the name of the master system on which you created the archive. master is the value for the creation_master keyword. If you do not specify master, flar create uses the system name that is reported by uname -n.
-e descr
Uses descr for the value of the content_description keyword. You cannot use this option when you use the -E option.
-E descr_file
Retrieves the value for the content_description keyword from the descr_file file. You cannot use this option when you use the -e option.
-a author
Uses author as the author name in the Archive Identification section. author is the value for the content_author keyword. If you do not specify an author, flar create does not include the content_author keyword in the Archive Identification section.
-T type
Uses type as the value for the content_type keyword. type is user defined. If you do not specify a type, flar create does not include the content_type keyword.
