Solaris Dynamic Tracing Guide
Chapter 9 Aggregations
When instrumenting the system to answer performance-related questions, it is useful to consider how data can be aggregated to answer a specific question rather than thinking in terms of data gathered by individual probes. For example, if you wanted to know the number of system calls by user ID, you would not necessarily care about the datum collected at each system call. You simply want to see a table of user IDs and system calls. Historically, you would answer this question by gathering data at each system call, and postprocessing the data using a tool like awk(1) or perl(1). However, in DTrace the aggregating of data is a first-class operation. This chapter describes the DTrace facilities for manipulating aggregations.
Aggregating Functions
An aggregating function is one that has the following property:
f(f(x0) U f(x1) U ... U f(xn)) = f(x0 U x1 U ... U xn)
where xn is a set of arbitrary data. That is, applying an aggregating function to subsets of the whole and then applying it again to the results gives the same result as applying it to the whole itself. For example, consider a function SUM that yields the summation of a given data set. If the raw data consists of {2, 1, 2, 5, 4, 3, 6, 4, 2}, the result of applying SUM to the entire set is {29}. Similarly, the result of applying SUM to the subset consisting of the first three elements is {5}, the result of applying SUM to the set consisting of the subsequent three elements is {12}, and the result of of applying SUM to the remaining three elements is also {12}. SUM is an aggregating function because applying it to the set of these results, {5, 12, 12}, yields the same result, {29}, as applying SUM to the original data.
Not all functions are aggregating functions. An example of a non-aggregating function is the function MEDIAN that determines the median element of the set. (The median is defined to be that element of a set for which as many elements in the set are greater than it as are less than it.) The MEDIAN is derived by sorting the set and selecting the middle element. Returning to the original raw data, if MEDIAN is applied to the set consisting of the first three elements, the result is {2}. (The sorted set is {1, 2, 2}; {2} is the set consisting of the middle element.) Likewise, applying MEDIAN to the next three elements yields {4} and applying MEDIAN to the final three elements yields {4}. Applying MEDIAN to each of the subsets thus yields the set {2, 4, 4}. Applying MEDIAN to this set yields the result {4}. However, sorting the original set yields {1, 2, 2, 2, 3, 4, 4, 5, 6}. Applying MEDIAN to this set thus yields {3}. Because these results do not match, MEDIAN is not an aggregating function.
Many common functions for understanding a set of data are aggregating functions. These functions include counting the number of elements in the set, computing the minimum value of the set, computing the maximum value of the set, and summing all elements in the set. Determining the arithmetic mean of the set can be constructed from the function to count the number of elements in the set and the function to sum the number the elements in the set.
However, several useful functions are not aggregating functions. These functions include computing the mode (the most common element) of a set, the median value of the set, or the standard deviation of the set.
Applying aggregating functions to data as it is traced has a number of advantages:
Aggregations
DTrace stores the results of aggregating functions in objects called aggregations. The aggregation results are indexed using a tuple of expressions similar to those used for associative arrays. In D, the syntax for an aggregation is:
@name[ keys ] = aggfunc ( args );
where name is the name of the aggregation, keys is a comma-separated list of D expressions, aggfunc is one of the DTrace aggregating functions, and args is a comma-separated list of arguments appropriate for the aggregating function. The aggregation name is a D identifier that is prefixed with the special character @. All aggregations named in your D programs are global variables; there are no thread- or clause-local aggregations. The aggregation names are kept in a separate identifier namespace from other D global variables. Remember that a and @a are not the same variable if you reuse names. The special aggregation name @ can be used to name an anonymous aggregation in simple D programs. The D compiler treats this name as an alias for the aggregation name @_.
The DTrace aggregating functions are shown in the following table. Most aggregating functions take just a single argument that represents the new datum.
Table 9–1 DTrace Aggregating Functions
Function Name
Arguments
Result
count
none
The number of times called.
sum
scalar expression
The total value of the specified expressions.
avg
scalar expression
The arithmetic average of the specified expressions.
min
scalar expression
The smallest value among the specified expressions.
max
scalar expression
The largest value among the specified expressions.
lquantize
scalar expression, lower bound, upper bound, step value
A linear frequency distribution, sized by the specified range, of the values of the specified expressions. Increments the value in the highest bucket that is less than the specified expression.
quantize
scalar expression
A power-of-two frequency distribution of the values of the specified expressions. Increments the value in the highest power-of-two bucket that is less than the specified expression.
For example, to count the number of write(2) system calls in the system, you could use an informative string as a key and the count() aggregating function:
syscall::write:entry
	@counts["write system calls"] = count();
The dtrace command prints aggregation results by default when the process terminates, either as the result of an explicit END action or when the user presses Control-C. The following example output shows the result of running this command, waiting for a few seconds, and pressing Control-C:
# dtrace -s writes.d
dtrace: script './writes.d' matched 1 probe
^C
  write system calls                                              179
You can count system calls per process name using the execname variable as the key to an aggregation:
	@counts[execname] = count();
# dtrace -s writesbycmd.d
dtrace: script './writesbycmd.d' matched 1 probe
^C
  dtrace                                                            1
  cat                                                               4
  sed                                                               9
  head                                                              9
  grep                                                             14
  find                                                             15
  tail                                                             25
  mountd                                                           28
  expr                                                             72
  sh                                                              291
  tee                                                             814
  def.dir.flp                                                    1996
  make.bin                                                       2010
Alternatively, you might want to further examine writes organized by both executable name and file descriptor. The file descriptor is the first argument to write(2), so the following example uses a key consisting of both execname and arg0:
	@counts[execname, arg0] = count();
Running this command results in a table with both executable name and file descriptor, as shown in the following example:
# dtrace -s writesbycmdfd.d
dtrace: script './writesbycmdfd.d' matched 1 probe
^C
  cat                                                               1      58
  sed                                                               1      60
  grep                                                              1      89
  tee                                                               1     156
  tee                                                               3     156
  make.bin                                                          5     164
  acomp                                                             1     263
  macrogen                                                          4     286
  cg        1     397
  acomp                                                             3     736
  make.bin                                                          1     880
  iropt                                                             4    1731
The following example displays the average time spent in the write system call, organized by process name. This example uses the avg() aggregating function, specifying the expression to average as the argument. The example averages the wall clock time spent in the system call:
	self->ts = timestamp;
syscall::write:return
/self->ts/
	@time[execname] = avg(timestamp - self->ts);
	self->ts = 0;
# dtrace -s writetime.d
dtrace: script './writetime.d' matched 2 probes
^C
  iropt                                                         31315
  acomp                                                         37037
  make.bin                                                      63736
  tee                                                           68702
  date                                                          84020
  sh                                                            91632
  dtrace                                                       159200
  ctfmerge                                                     321560
  install                                                      343300
  mcs                                                          394400
  get                                                          413695
  ctfconvert                                                   594400
  bringover                                                   1332465
  tail                                                        1335260
The average can be useful, but often does not provide sufficient detail to understand the distribution of data points. To understand the distribution in further detail, use the quantize() aggregating function as shown in the following example:
/self->ts/
	@time[execname] = quantize(timestamp - self->ts);
	self->ts = 0;
Because each line of output becomes a frequency distribution diagram, the output of this script is substantially longer than previous ones. The following example shows a selection of sample output:
  lint
           value  ------------- Distribution ------------- count
            8192 |                                         0
           16384 |                                         2
           32768 |                                         0
           65536 |@@@@@@@@@@@@@@@@@@@                      74
          131072 |@@@@@@@@@@@@@@@                          59
          262144 |@@@                                      14
          524288 |                                         0
  acomp
            4096 |                                         0
            8192 |@@@@@@@@@@@@                             840
           16384 |@@@@@@@@@@@                              750
           32768 |@@                                       165
           65536 |@@@@@@                                   460
          131072 |@@@@@@                                   446
          262144 |                                         16
          524288 |                                         0
         1048576 |                                         1
         2097152 |                                         0
  iropt
            4096 |                                         0
            8192 |@@@@@@@@@@@@@@@@@@@@@@@                  4149
           16384 |@@@@@@@@@@                               1798
           32768 |@                                        332
           65536 |@                                        325
          131072 |@@                                       431
          262144 |                                         3
          524288 |                                         2
         1048576 |                                         1
         2097152 |                                         0
Notice that the rows for the frequency distribution are always power-of-two values. Each rows indicates the count of the number of elements greater than or equal to the corresponding value, but less than the next larger row value. For example, the above output shows that iropt had 4,149 writes taking between 8,192 nanoseconds and 16,383 nanoseconds, inclusive.
While quantize() is useful for getting quick insight into the data, you might want to examine a distribution across linear values instead. To display a linear value distribution, use the lquantize() aggregating function. The lquantize() function takes three arguments in addition to a D expression: a lower bound, an upper bound, and a step. For example, if you wanted to look at the distribution of writes by file descriptor, a power-of-two quantization would not be effective. Instead, use a linear quantization with a small range, as shown in the following example:
	@fds[execname] = lquantize(arg0, 0, 100, 1);
Running this script for several seconds yields a large amount of information. The following example shows a selection of typical output:
  mountd
              11 |                                         0
              12 |@                                        4
              13 |                                         0
              14 |@@@@@@@@@@@@@@@@@@@@@@@@@                70
              15 |                                         0
              16 |@@@@@@@@@@@@                             34
              17 |                                         0
  xemacs-20.4
               6 |                                         0
               7 |@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@  521
               8 |                                         0
               9 |                                         1
              10 |                                         0
  make.bin
               0 |                                         0
               1 |@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@  3596
               2 |                                         0
               3 |                                         0
               4 |                                         42
               5 |                                         50
               6 |                                         0
  acomp
               0 |                                         0
               1 |@@@@@                                    1156
               2 |                                         0
               3 |@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@         6635
               4 |@                                        297
               5 |                                         0
  iropt
               2 |                                         0
               3 |                                         299
               4 |@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@  20144
               5 |                                         0
You can also use the lquantize() aggregating function to aggregate on time since some point in the past. This technique allows you to observe a change in behavior over time. The following example displays the change in system call behavior over the lifetime of a process executing the date(1) command:
syscall::exec:return,
syscall::exece:return
/execname == "date"/
	self->start = vtimestamp;
syscall:::entry
/self->start/
	 * We linearly quantize on the current virtual time minus our
	 * process's start time.  We divide by 1000 to yield microseconds
	 * rather than nanoseconds.  The range runs from 0 to 10 milliseconds
	 * in steps of 100 microseconds; we expect that no date(1) process
	 * will take longer than 10 milliseconds to complete.
	@a["system calls over time"] =
	    lquantize((vtimestamp - self->start) / 1000, 0, 10000, 100);
syscall::rexit:entry
/self->start/
	self->start = 0;
The preceding script provides greater insight into system call behavior when many date(1) processes are executed. To see this result, run sh -c 'while true; do date >/dev/null; done' in one window, while executing the D script in another. The script produces a profile of the system call behavior of the date(1) command:
# dtrace -s dateprof.d
dtrace: script './dateprof.d' matched 218 probes
^C
             < 0 |                                         0
               0 |@@                                       20530
             100 |@@@@@@                                   48814
             200 |@@@                                      28119
             300 |@                                        14646
             400 |@@@@@                                    41237
             500 |                                         1259
             600 |                                         218
             700 |                                         116
             800 |@                                        12783
             900 |@@@                                      28133
            1000 |                                         7897
            1100 |@                                        14065
            1200 |@@@                                      27549
            1300 |@@@                                      25715
            1400 |@@@@                                     35011
            1500 |@@                                       16734
            1600 |                                         498
            1700 |                                         256
            1800 |                                         369
            1900 |                                         404
            2000 |                                         320
            2100 |                                         555
            2200 |                                         54
            2300 |                                         17
            2400 |                                         5
            2500 |                                         1
            2600 |                                         7
            2700 |                                         0
This output provides a rough idea of the different phases of the date(1) command with respect to the services required of the kernel. To better understand these phases, you might want to understand which system calls are being called when. If so, you could change the D script to aggregate on the variable probefunc instead of a constant string.
Printing Aggregations
By default, multiple aggregations are displayed in the order they are introduced in the D program. You can override this behavior using the printa() function to print the aggregations. The printa() function also enables you to precisely format the aggregation data using a format string, as described in Chapter 12, Output Formatting.
If an aggregation is not formatted with a printa() statement in your D program, the dtrace command will snapshot the aggregation data and print the results once after tracing has completed using the default aggregation format. If a given aggregation is formatted using a printa() statement, the default behavior is disabled. You can achieve equivalent results by adding the statement printa(@aggregation-name) to a dtrace:::END probe clause in your program. The default output format for the avg(), count(), min(), max(), and sum() aggregating functions displays an integer decimal value corresponding to the aggregated value for each tuple. The default output format for the lquantize() and quantize() aggregating functions displays an ASCII table of the results. Aggregation tuples are printed as if trace() had been applied to each tuple element.
Data Normalization
When aggregating data over some period of time, you might want to normalize the data with respect to some constant factor. This technique enables you to compare disjoint data more easily. For example, when aggregating system calls, you might want to output system calls as a per-second rate instead of as an absolute value over the course of the run. The DTrace normalize() action enables you to normalize data in this way. The parameters to normalize() are an aggregation and a normalization factor. The output of the aggregation shows each value divided by the normalization factor.
The following example shows how to aggregate data by system call:
#pragma D option quiet
BEGIN
	 * Get the start time, in nanoseconds.
	start = timestamp;
syscall:::entry
	@func[execname] = count();
END
	 * Normalize the aggregation based on the number of seconds we have
	 * been running.  (There are 1,000,000,000 nanoseconds in one second.)
	normalize(@func, (timestamp - start) / 1000000000);
Running the above script for a brief period of time results in the following output on a desktop machine:
# dtrace -s ./normalize.d
 ^C
  syslogd                                                           0
  rpc.rusersd                                                       0
  utmpd                                                             0
  xbiff                                                             0
  in.routed                                                         1
  sendmail                                                          2
  echo                                                              2
  FvwmAuto                                                          2
  stty                                                              2
  cut                                                               2
  init                                                              2
  pt_chmod                                                          3
  picld                                                             3
  utmp_update                                                       3
  httpd                                                             4
  xclock                                                            5
  basename                                                          6
  tput                                                              6
  sh        7
  tr        7
  arch                                                              9
  expr                                                             10
  uname                                                            11
  mibiisa                                                          15
  dirname                                                          18
  dtrace                                                           40
  ksh                                                              48
  java                                                             58
  xterm                                                           100
  nscd                                                            120
  fvwm2                                                           154
  prstat                                                          180
  perfbar                                                         188
  Xsun                                                           1309
  .netscape.bin                                                  3005
normalize() sets the normalization factor for the specified aggregation, but this action does not modify the underlying data. denormalize() takes only an aggregation. Adding the denormalize action to the preceding example returns both raw system call counts and per-second rates:
BEGIN
	start = timestamp;
syscall:::entry
END
	this->seconds = (timestamp - start) / 1000000000;
	printf("Ran for %d seconds.\n", this->seconds);
	printf("Per-second rate:\n");
	normalize(@func, this->seconds);
	printa(@func);
	printf("\nRaw counts:\n");
	denormalize(@func);
	printa(@func);
Running the above script for a brief period of time produces output similar to the following example:
# dtrace -s ./denorm.d
^C
Ran for 14 seconds.
Per-second rate:
  syslogd                                                           0
  in.routed                                                         0
  xbiff                                                             1
  sendmail                                                          2
  elm                                                               2
  picld                                                             3
  httpd                                                             4
  xclock                                                            6
  FvwmAuto                                                          7
  mibiisa                                                          22
  dtrace                                                           42
  java                                                             55
  xterm                                                            75
  adeptedit                                                       118
  nscd                                                            127
  prstat                                                          179
  perfbar                                                         184
  fvwm2                                                           296
  Xsun                                                            829
Raw counts:
  syslogd                                                           1
  in.routed                                                         4
  xbiff                                                            21
  sendmail                                                         30
  elm                                                              36
  picld                                                            43
  httpd                                                            56
  xclock                                                           91
  FvwmAuto                                                        104
  mibiisa                                                         314
  dtrace                                                          592
  java                                                            774
  xterm                                                          1062
  adeptedit                                                      1665
  nscd                                                           1781
  prstat                                                         2506
  perfbar                                                        2581
  fvwm2                                                          4156
  Xsun                                                          11616
Aggregations can also be renormalized. If normalize() is called more than once for the same aggregation, the normalization factor will be the factor specified in the most recent call. The following example prints per-second rates over time:
Example 9–1 renormalize.d: Renormalizing an Aggregation
BEGIN
	start = timestamp;
syscall:::entry
tick-10sec
	printa(@func);
Clearing Aggregations
When using DTrace to build simple monitoring scripts, you can periodically clear the values in an aggregation using the clear() function. This function takes an aggregation as its only parameter. The clear() function clears only the aggregation's values; the aggregation's keys are retained. Therefore, the presence of a key in an aggregation that has an associated value of zero indicates that the key had a non-zero value that was subsequently set to zero as part of a clear(). To discard both an aggregation's values and its keys, use the trunc(). See Truncating aggregations for details.
The following example adds clear() to Example 9–1:
BEGIN
	last = timestamp;
syscall:::entry
tick-10sec
	normalize(@func, (timestamp - last) / 1000000000);
	printa(@func);
	clear(@func);
	last = timestamp;
While Example 9–1 shows the system call rate over the lifetime of the dtrace invocation, the preceding example shows the system call rate only for the most recent ten-second period.
When looking at aggregation results, you often care only about the top several results. The keys and values associated with anything other than the highest values are not interesting. You might also wish to discard an entire aggregation result, removing both keys and values. The DTrace trunc() function is used for both of these situations.
The parameters to trunc() are an aggregation and an optional truncation value. Without the truncation value, trunc() discards both aggregation values and aggregation keys for the entire aggregation. When a truncation value n is present, trunc() discards aggregation values and keys except for those values and keys associated with the highest n values. That is, trunc(@foo, 10) truncates the aggregation named foo after the top ten values, where trunc(@foo) discards the entire aggregation. The entire aggregation is also discarded if 0 is specified as the truncation value.
To see the bottom n values instead of the top n, specify a negative truncation value to trunc(). For example, trunc(@foo, -10) truncates the aggregation named foo after the bottom ten values.
The following example augments the system call example to only display the per-second system call rates of the top ten system-calling applications in a ten-second period:
BEGIN
	last = timestamp;
syscall:::entry
tick-10sec
	trunc(@func, 10);
	printa(@func);
	clear(@func);
	last = timestamp;
The following example shows output from running the above script on a lightly loaded laptop:
  FvwmAuto                                                          7
  telnet                                                           13
  ping                                                             14
  dtrace                                                           27
  xclock                                                           34
  MozillaFirebird-                                                 63
  xterm                                                           133
  fvwm2                                                           146
  acroread                                                        168
  Xsun                                                            616
  telnet                                                            4
  FvwmAuto                                                          5
  ping                                                             14
  dtrace                                                           27
  xclock                                                           35
  fvwm2                                                            69
  xterm                                                            70
  acroread                                                        164
  MozillaFirebird-                                                491
  Xsun                                                           1287
Minimizing Drops
Because DTrace buffers some aggregation data in the kernel, space might not be available when a new key is added to an aggregation. In this case, the data will be dropped, a counter will be incremented, and dtrace will generate a message indicating an aggregation drop. This situation rarely occurs because DTrace keeps long-running state (consisting of the aggregation's key and intermediate result) at user-level where space may grow dynamically. In the unlikely event that aggregation drops occur, you can increase the aggregation buffer size with the aggsize option to reduce the likelihood of drops. You can also use this option to minimize the memory footprint of DTrace. As with any size option, aggsize may be specified with any size suffix. The resizing policy of this buffer is dictated by the bufresize option. For more details on buffering, see Chapter 11, Buffers and Buffering. For more details on options, see Chapter 16, Options and Tunables.
An alternative method to eliminate aggregation drops is to increase the rate at which aggregation data is consumed at user-level. This rate defaults to once per second, and may be explicitly tuned with the aggrate option. As with any rate option, aggrate may be specified with any time suffix, but defaults to rate-per-second. For more details on the aggsize option, see Chapter 16, Options and Tunables.
