Solaris Dynamic Tracing Guide
Spin Lock Probes
Threads cannot block in some contexts in the kernel, such as high-level interrupt context and any context manipulating dispatcher state. In these contexts, this restriction prevents the use of adaptive locks. Spin locks are instead used to effect mutual exclusion to critical sections in these contexts. As the name implies, the behavior of these locks in the presence of contention is to spin until the lock is released by the owning thread. The three probes pertaining to spin locks are in Table 18–2.
Table 18–2 Spin Lock Probes
Hold-event probe that fires immediately after a spin lock is acquired.
Contention-event probe that fires after a thread that has spun on a held spin lock has successfully acquired the spin lock. If both are enabled, spin-spin fires before spin-acquire. arg1 for spin-spin contains the spin time: the number of nanoseconds that were spent in the spin state before the lock was acquired. The spin count has little meaning on its own, but can be used to compare spin times.
Hold-event probe that fires immediately after a spin lock is released.
Adaptive locks are much more common than spin locks. The following script displays totals for both lock types to provide data to support this observation.
/execname == "date"/
	@locks["adaptive"] = count();
	@locks["spin"] = count();
Run this script in one window, and a date(1) command in another. When you terminate the DTrace script, you will see output similar to the following example:
# dtrace -s ./whatlock.d
dtrace: script './whatlock.d' matched 5 probes
spin                                                             26
adaptive                                                       2981
As this output indicates, over 99 percent of the locks acquired in running the date command are adaptive locks. It may be surprising that so many locks are acquired in doing something as simple as a date. The large number of locks is a natural artifact of the fine-grained locking required of an extremely scalable system like the Solaris kernel.
