Solaris Dynamic Tracing Guide
change-pri
Preemption is based on priorities, so you might want to observe changes in priority over time. The following example uses the change-pri probe to display this information:
sched:::change-pri
	@[stringof(args[0]->pr_clname)] =
	    lquantize(args[2] - args[0]->pr_pri, -50, 50, 5);
The example script captures the degree to which priority is raised or lowered, and aggregates by scheduling class. Running the above script results in output similar to the following example:
# dtrace -s ./pri.d
dtrace: script './pri.d' matched 10 probes
^C
 IA
           value  -------------- Distribution ------------ count
           < -50 |                                         20
             -50 |@                                        38
             -45 |                                         4
             -40 |                                         13
             -35 |                                         12
             -30 |                                         18
             -25 |                                         18
             -20 |                                         23
             -15 |                                         6
             -10 |@@@@@@@@                                 201
              -5 |@@@@@@                                   160
               0 |@@@@@                                    138
               5 |@                                        47
              10 |@@                                       66
              15 |@                                        36
              20 |@                                        26
              25 |@                                        28
              30 |                                         18
              35 |                                         22
              40 |                                         8
              45 |                                         11
           >= 50 |@                                        34
  TS
             -15 |                                         0
             -10 |@                                        1
              -5 |@@@@@@@@@@@@                             7
               0 |@@@@@@@@@@@@@@@@@@@@                     12
               5 |                                         0
              10 |@@@@@                                    3
              15 |                                         0
The output shows the priority manipulation of the Interactive (IA) scheduling class. Instead of seeing priority manipulation, you might want to see the priority values of a particular process and thread over time. The following script uses the change-pri probe to display this information:
#pragma D option quiet
BEGIN
	start = timestamp;
sched:::change-pri
/args[1]->pr_pid == $1 && args[0]->pr_lwpid == $2/
	printf("%d %d\n", timestamp - start, args[2]);
tick-1sec
/++n == 5/
	exit(0);
To see the change in priorities over time, type the following command in one window:
$ echo $$
139208
$ while true ; do let i=0 ; done
In another window, run the script and redirect the output to a file:
# dtrace -s ./pritime.d 139208 1 > /tmp/pritime.out
You can use the file /tmp/pritime.out that is generated above as input to plotting software to graphically display priority over time. gnuplot is a freely available plotting package that is included in the Solaris Freeware Companion CD. By default, gnuplot is installed in /opt/sfw/bin.
