D provides the binary arithmetic operators shown in the following table for use in your programs. These operators all have the same meaning for integers as they do in ANSI-C.
Table 2–6 D Binary Arithmetic Operators
integer addition |
integer subtraction |
integer multiplication |
integer division |
integer modulus |
Arithmetic in D may only be performed on integer operands, or on pointers, as discussed in Chapter 5, Pointers and Arrays. Arithmetic may not be performed on floating-point operands in D programs. The DTrace execution environment does not take any action on integer overflow or underflow. You must check for these conditions yourself in situations where overflow and underflow can occur.
The DTrace execution environment does automatically check for and report division by zero errors resulting from improper use of the / and % operators. If a D program executes an invalid division operation, DTrace will automatically disable the affected instrumentation and report the error. Errors detected by DTrace have no effect on other DTrace users or on the operating system kernel, so you don't need to worry about causing any damage if your D program inadvertently contains one of these errors.
In addition to these binary operators, the + and - operators may also be used as unary operators as well; these operators have higher precedence than any of the binary arithmetic operators. The order of precedence and associativity properties for all the D operators is presented in Table 2–11. You can control precedence by grouping expressions in parentheses ( ).
