JDK for Solaris Developer's Guide
Improved Support for Environment Variables
The System.getenv(String) method is no longer deprecated. The new System.getenv() method allows access to the process environment as a Map<String,String>. Refer to the documentation at http://java.sun.com/j2se/1.5.0/docs/api/java/lang/System.html#getenv(java.lang.String).
