JDK for Solaris Developer's Guide
Integration Libraries
Remote Method Invocation (RMI)
RMI has been enhanced in the following areas:
Refer to the documentation at http://java.sun.com/j2se/1.5.0/docs/guide/rmi/index.html.
Java Database Connectivity (JDBC)
RowSet interface, part of the javax.sql package, introduced in J2SE version 1.4, provides a lightweight means of passing data between components.
At this release, as an aid to developers, the RowSet interface has been implemented (as JSR 114) in five of the more common ways a RowSet object can be used. These implementations provide a standard that developers are free to use as is or to extend. Following are the five standard implementations:
Refer to the documentation at http://java.sun.com/j2se/1.5.0/docs/guide/jdbc/index.html.
Enhancements to CORBA, Java IDL, and Java RMI-IIOP are discussed in Changes in CORBA Features Between J2SE 1.4.x and 1.5.0. Refer to the Java IDL documentation at http://java.sun.com/j2se/1.5.0/docs/guide/idl/index.html and to the Java RMI-IIOP documentation at http://java.sun.com/j2se/1.5.0/docs/guide/rmi-iiop/index.html.
Java Naming and Directory InterfaceTM (JNDI)
JNDI provides the following new features.
Refer to the documentation at http://java.sun.com/j2se/1.5.0/docs/guide/jndi/index.html.
