JDK for Solaris Developer's Guide
The new ProcessBuilder class provides a more convenient way to invoke subprocesses than does Runtime.exec. In particular, ProcessBuilder makes it easy to start a subprocess with a modified process environment (that is, one based on the parent's process environment, but with a few changes). Refer also to the documentation at http://java.sun.com/j2se/1.5.0/docs/api/java/lang/ProcessBuilder.html.
