以下範例顯示如何在具有 500 MB 磁碟的 x86 系統上建立單一磁碟配置檔 500_test。
首先,您必須先將 fdisk 指令的輸出結果儲存到一個名為 500_test 的檔案中:
# fdisk -R -W 500_test -h /dev/rdsk/c0t0d0p0 |
500_test 檔案如下所示:
* /dev/rdsk/c0t0d0p0 default fdisk table * Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1455 cylinders * * HBA Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1455 cylinders * * systid: * 1: DOSOS12 * 2: PCIXOS * 4: DOSOS16 * 5: EXTDOS * 6: DOSBIG * 86: DOSDATA * 98: OTHEROS * 99: UNIXOS * 130: SUNIXOS * * Id Act Bhead Bsect Bcyl Ehead Esect Ecyl Rsect Numsect 130 128 44 3 0 46 30 1001 1410 2050140 |
然後,將 prtvtoc 指令的輸出結果附加到 500_test 檔案:
# prtvtoc /dev/rdsk/c0t0d0s2 >>500_test |
現在,500_test 檔案是一個完整的磁碟配置檔:
* /dev/rdsk/c0t0d0p0 default fdisk table * Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1455 cylinders * * HBA Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1455 cylinders * * systid: * 1: DOSOS12 * 2: PCIXOS * 4: DOSOS16 * 5: EXTDOS * 6: DOSBIG * 86: DOSDATA * 98: OTHEROS * 99: UNIXOS * 130: SUNIXOS * * Id Act Bhead Bsect Bcyl Ehead Esec Ecyl Rsect Numsect 130 128 44 3 0 46 30 1001 1410 2050140 * /dev/rdsk/c0t0d0s2 partition map * * Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1110 sectors/cylinder * 1454 cylinders * 1452 accessible cylinders * * Flags: * 1: unmountable * 10: read-only * First Sector Last * Partition Tag Flags Sector Count Sector Mount Directory 2 5 01 1410 2045910 2047319 7 6 00 4230 2043090 2047319 /space 8 1 01 0 1410 1409 9 9 01 1410 2820 422987 |
您已經為基於 x86 的系統建立了磁碟配置檔。測試設定檔包含使用磁碟配置檔測試設定檔的相關資訊。
