Oracle Solaris Trusted Extensions User's Guide
ProcedureHow to Move a Window to a Different Workspace
Windows that are moved to a different workspace retain their original label. Any actions that are done in those windows are done at the label of the window, not at the label of the containing workspace. Moving a window is useful when you want to compare information. You might also want to use applications at different labels without moving between workspaces.
  1. To move a window to a different workspace, perform one of the following:
    • In Trusted CDE, use the Occupy Workspace menu.
      1. From the application's window menu, choose Occupy Workspace.
        Figure 3–11 Occupy Workspace Menu in Trusted CDE
        Screen shows the Occupy Workspace dialog box.
      2. Choose a workspace at a different label, then click OK.
        This action moves the application to a workspace that has a different label. Note that the Occupy Workspace dialog box has the label Trusted Path. This label indicates that occupying a workspace affects the trusted computing base.
        The following figure shows two terminal windows at different labels in one workspace.
        Figure 3–12 Differently Labeled Windows in One Workspace
        Screen shows a Public window and a Confidential window
in one workspace.
    • In Trusted JDS, in the panel display, drag the window from its original workspace panel to a different panel.
      The dragged window now appears in the second workspace.
