Oracle Solaris Trusted Extensions Developer's Guide
Setting a Window Label
This example shows how to set the sensitivity label on a window. The new sensitivity label dominates the sensitivity label of the window and the process. The client needs the sys_trans_label privilege in its effective set to translate a label that the client does not dominate. The client also needs the win_upgrade_sl privilege to change the window's sensitivity label.
For more information about using privileges, see Oracle Solaris Security for Developers Guide.
/* Translate text string to sensitivity label */
   retval = label_to_str(string4, &label, M_LABEL, L_NO_CORRECTION, &error);
/* Set sensitivity label with new value */
   retval = XTSOLsetResLabel(display, window, IsWindow, label);
