Oracle Solaris Trusted Extensions Administrator's Procedures
Chapter 18 Trusted Extensions Auditing (Overview)
This chapter describes the additions to auditing that Solaris Trusted Extensions provides.
Trusted Extensions and Auditing
On a system that is configured with Trusted Extensions software, auditing is configured and is administered similarly to auditing on a Solaris system. However, the following are some differences.
Audit Management by Role in Trusted Extensions
Auditing in Trusted Extensions requires the same planning as in the Solaris OS. For details about planning, see Chapter 29, Planning for Solaris Auditing, in System Administration Guide: Security Services.
Role Setup for Audit Administration
In Trusted Extensions, auditing is the responsibility of two roles. The System Administrator role sets up the disks and the network of audit storage. The Security Administrator role decides what is to be audited, and specifies the information in the audit configuration files. As in the Solaris OS, you create the roles in software. The rights profiles for these two roles are provided. The initial setup team created the Security Administrator role during initial configuration. For details, see Create the Security Administrator Role in Trusted Extensions in Oracle Solaris Trusted Extensions Configuration Guide.
Note –
A system only records the security-relevant events that the audit configuration files configure the system to record (that is, by preselection). Therefore, any subsequent audit review can only consider the events that have been recorded. As a result of misconfiguration, attempts to breach the security of the system can go undetected, or the administrator is unable to detect the user who is responsible for an attempted breach of security. Administrators must regularly analyze audit trails to check for breaches of security.
Audit Tasks in Trusted Extensions
The procedures to configure and manage auditing in Trusted Extensions differ slightly from Solaris procedures:
Audit Tasks of the Security Administrator
The following tasks are security-relevant, and are therefore the responsibility of the security administrator. Follow the Solaris instructions, but use the Trusted Extensions administrative tools.
Task
For Solaris Instructions
Trusted Extensions Instructions
Configure audit files.
Configuring Audit Files (Task Map) in System Administration Guide: Security Services
Use the trusted editor. For details, see How to Edit Administrative Files in Trusted Extensions.
(Optional) Change default audit policy.
How to Configure Audit Policy in System Administration Guide: Security Services
Disable and re-enable auditing.
How to Disable the Audit Service in System Administration Guide: Security Services
Auditing is enabled by default.
Manage auditing.
Solaris Auditing (Task Map) in System Administration Guide: Security Services
Ignore per-zone audit tasks.
Audit Tasks of the System Administrator
The following tasks are the responsibility of the system administrator. Follow the Solaris instructions, but use the Trusted Extensions administrative tools.
Task
Create audit partitions and an audit administration server, export audit partitions, and mount audit partitions.
Create an audit_warn alias.
Configuring and Enabling the Audit Service (Tasks) in System Administration Guide: Security Services
Perform all administration in the global zone.
Copy or loopback mount customized audit files to labeled zones.
Configuring the Audit Service in Zones (Tasks) in System Administration Guide: Security Services
Copy the files to the first labeled zone, then copy the zone.
Or, loopback mount or copy the files to every labeled zone after the zones are created.
(Optional) Distribute audit configuration files.
No instructions
See How to Copy Files From Portable Media in Trusted Extensions in Oracle Solaris Trusted Extensions Configuration Guide
Manage auditing.
Select audit records by label.
How to Select Audit Events From the Audit Trail in System Administration Guide: Security Services
To select records by label, use the auditreduce command with the -l option.
Trusted Extensions Audit Reference
Trusted Extensions software adds audit classes, audit events, audit tokens, and audit policy options to the Solaris OS. Several auditing commands are extended to handle labels. Trusted Extensions audit records include a label, as shown in the following figure.
Figure 18–1 Typical Audit Record on a Labeled System
Illustration shows four tokens in order - header, subject,
label, and return - that comprise a typical audit record.
Trusted Extensions Audit Classes
The audit classes that Trusted Extensions software adds to the Solaris OS are listed alphabetically in the following table. The classes are listed in the /etc/security/audit_class file. For more information about audit classes, see the audit_class(4) man page.
Table 18–1 X Server Audit Classes
Short Name
Long Name
Audit Mask
xc
X - Object create/destroy
0x00800000
xp
X - Privileged/administrative operations
0x00400000
xs
X - Operations that always silently fail, if bad
0x02000000
xx
X - All X events in the xl, xc, xp, and xs classes (metaclass)
0x03e00000
The X server audit events are mapped to these classes according to the following criteria:
Trusted Extensions Audit Events
Trusted Extensions software adds audit events to the system. The new audit events and the audit classes to which the events belong are listed in the /etc/security/audit_event file. The audit event numbers for Trusted Extensions are between 9000 and 10000. For more information about audit events, see the audit_event(4) man page.
Trusted Extensions Audit Tokens
The audit tokens that Trusted Extensions software adds to the Solaris OS are listed alphabetically in the following table. The tokens are also listed in the audit.log(4) man page.
Table 18–2 Trusted Extensions Audit Tokens
Token Name
Description
label Token
Sensitivity label
xatom Token
X window atom identification
xclient Token
X client identification
xcolormap Token
X window color information
xcursor Token
X window cursor information
xfont Token
X window font information
xgc Token
X window graphical context information
xpixmap Token
Xwindow pixel mapping information
xproperty Token
X window property information
xselect Token
X window data information
xwindow Token
X window window information
label Token
The label token contains a sensitivity label. This token contains the following fields:
The following figure shows the token format.
Figure 18–2 label Token Format
The context describes the graphic.
A label token is displayed by the praudit command as follows:
sensitivity label,ADMIN_LOW
xatom Token
The xatom token contains information concerning an X atom. This token contains the following fields:
An xatom token is displayed by praudit as follows:
X atom,_DT_SAVE_MODE
xclient Token
The xclient token contains information concerning the X client. This token contains the following fields:
An xclient token is displayed by praudit as follows:
X client,15
xcolormap Token
The xcolormap token contains information about the colormaps. This token contains the following fields:
Figure 18–3 Format for xcolormap, xcursor, xfont, xgc, xpixmap, and xwindow Tokens
An xcolormap token is displayed by praudit as follows:
X color map,0x08c00005,srv
xcursor Token
The xcursor token contains information about the cursors. This token contains the following fields:
Figure 18–3 shows the token format.
An xcursor token is displayed by praudit as follows:
X cursor,0x0f400006,srv
xfont Token
The xfont token contains information about the fonts. This token contains the following fields:
An xfont token is displayed by praudit as follows:
X font,0x08c00001,srv
xgc Token
The xgc token contains information about the xgc. This token contains the following fields:
An xgc token is displayed by praudit as follows:
Xgraphic context,0x002f2ca0,srv
xpixmap Token
The xpixmap token contains information about the pixel mappings. This token contains the following fields:
An xpixmap token is displayed by praudit as follows:
X pixmap,0x08c00005,srv
xproperty Token
The xproperty token contains information about various properties of a window. This token contains the following fields:
The following figure shows an xproperty token format.
Figure 18–4 xproperty Token Format
An xproperty token is displayed by praudit as follows:
X property,0x000075d5,root,_MOTIF_DEFAULT_BINDINGS
xselect Token
The xselect token contains the data that is moved between windows. This data is a byte stream with no assumed internal structure and a property string. This token contains the following fields:
Figure 18–5 xselect Token Format
An xselect token is displayed by praudit as follows:
X selection,entryfield,halogen
xwindow Token
The xwindow token contains information about a window. This token contains the following fields:
An xwindow token is displayed by praudit as follows:
X window,0x07400001,srv
Trusted Extensions Audit Policy Options
Trusted Extensions adds two audit policy options to existing Solaris auditing policy options. List the policies to see the additions:
$ auditconfig -lspolicy
windata_down Include downgraded window information in audit records
windata_up   Include upgraded window information in audit records
Extensions to Auditing Commands in Trusted Extensions
The auditconfig, auditreduce, and bsmrecord commands are extended to handle Trusted Extensions information:
